Thread: 7G Auto -> 5spd conversion...
Page 4 of 5 FirstFirst 12345 LastLast
Showing results 61 to 80 of 92
  1. #61
    Member da1085's Avatar
    01-03-2006
    202
    dang this thing is old!!!!!!!......but it's still holds alot of good infos....well since RGC is back i dont have the convo we all had about the swap.....the progress is on hold due to parts in transit.....this will be the longest 3 days of my life.....the earliest day parts might get to texas is on wednesday....well im stuck with nothing to do....just wondering to ask an old answered question.......can i reuse my auto starter?? im asking because maybe someone found a reason why we cant and maybe found a way for me to reuse it..
    1990 GSX(91 eprom ecu set-up)
    6-bolt jdm (GVR4)
    16G turbo
    3inch turbo back(flowmasters)
    510cc
    OSTRICH
    FMIC
  2. #62
    Bronx NYC (reppin)
    3,489
    its all in the posts dude.
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
  3. #63
    12-17-2002
    Sherman Oaks, California
    4,304
    can't use the auto starter. the gear isn't long enough to reach the teeth on the flywheel. seth says you can make it work with shims, but i took the easy way out and bought a 5spd starter, and brought back my auto pretending it was the 5spd one.
    http://socallifestyle.com/
    1994 Galant GS 5spd
  4. #64
    Bronx NYC (reppin)
    3,489
    lolol.
  5. #65
    Kansas City, MO
    1,244
    Ok found a way around the key release cable.
    The cable actually goes around to the back side of the steering column. so you have to romove the column casing and then you should see something like this.
    (The picture you see is after i already seperated the cable from the pieces that fall out of the white housing. You can see the end of the cable hanging to the side)
    remove the four bolts on the white plastic piece.it will fall off, and there are two more white plastic pieces that will come out that look like this.
    (the piece on the right is what attaches to the end of the cable)
    then you just pull the cable through the middle console and it's gone now. :D
  6. #66
    Bronx NYC (reppin)
    3,489
    nice.
  7. #67
    Kansas City, MO
    1,244
    about 60% done
  8. #68
    12-17-2002
    4,304
    what pillar pod is that? how well does it fit? how did you fasten it? do i ask too many questions?
    1994 Galant GS 5spd
  9. #69
    Bronx NYC (reppin)
    3,489
    ya, answer the questions mate.
  10. #70
    Kansas City, MO
    1,244
    Quote Originally Posted by peanotation
    It's one i got off ebay about two years ago. it doesn't havea smooth texture, but it fits ok. i drilled a hole between the top two pods and put a screw in that holds it in place. but it's made for 7th gen galant. i haven't seen one since though.
  11. #71
    01-03-2006
    202
    really nice set up man!! i like the pods.....im wondering i you can send me the site where i can find out what wire to splice into for the guages, speacialy the on that mst connect to the ecu....AF ratio or even all of them if you just connect all of the gueages reciever-wires to the ecu....you'll love having a 5spd galant!...i know i love mine....make sure to do the skateboard baring....im waiting out on the short shifter since mine was cut to length by the guy that i bought it from...not bad though, kinda "short" shifter but not to short....the bearing makes alot of difference...
    hope yo ucan help me out on the guage wiring(ECU hopefuly)
    6-bolt jdm (GVR4)
    16G turbo
    510cc
    OSTRICH
    FMIC
  12. #72
    Kansas City, MO
    1,244
    man i don't know jack about the ecu wiring, the first page has the set up for the oil presuure gauge, and the A/F is a wire tap from the engin bay. Th O2 sensor wires are located on the back of the engine near the intake manifold. i'll post pics tomorrow.
  13. #73
    CHH
    Whats the actual transmission number of the compatible gearbox?
    f5m22?
    will the one from this lancer work? http://www.trademe.co.nz/Trade-Me-Motors/C...on-72541370.htm
    Also I have a 6a12 not a 4g63 or 4g64, does that matter?
    My current auto model number is f4a23.
    Thanks for your help.
  14. #74
    Kansas City, MO
    1,244
    i would tell you that the manual tranny for the 4 cylinder engines will not bolt to the 6 cyl engine, but it's just an educated guess.i wou;d think you would need the manual transmission that came on 6 cylinder engines, say galant vr4's or 3000gt's. i would say to check first for the code of 6a12 vr4's tranny... good luck man.
  15. #75
    I really dont know the answer but I doubt a 4cyl trans will bolt up with the 4cyl stock bellhousing. I know the 6a13 guys can use the FWD trans from the FTO as they have a FWD non-turbo 6a13 motor to begin with. Other then that its hard to say. MIght just do some research on which cars in your country come stock with a FWD 6a12 other then the Galan and FTO.
    BTW, have no clue if the 6a13 trans will bolt up, but it would be a closer match then a 4cyl trans :P
  16. #76
    05-25-2006
    New York City
    1,028
    While doing the 5 speed swap this is a must if you plan to go turbo Teazer :D
    2000 Galant ES = Daily Driver
  17. #77
    12-17-2002
    4,304
    how'd you get the 8 bolts off of the ring? impact gun?
    1994 Galant GS 5spd
  18. #78
    Impact gun is a must. Unless you put the diff carefully in a vice and have some muscles and a breaker bar.
  19. #79
    05-25-2006
    New York City
    1,028
    Impact I have a compressor in the garage :D
  20. #80
    Bronx NYC (reppin)
    3,489
    Quote Originally Posted by Sleepervr-4
    Cosigned!!!
