Thread: 7th Gen vs. Eclipse Brakes...
Showing results 1 to 2 of 2
    Livn2sk8
    I have a 94 GS...with front and rear disc brakes...I really need new rotors and pads.....i'm happy with my current pads....(EBC Greenstuff).....but I need new ones desperately......
    Also...what...if any.....pads/rotors/brake lines...are compatible from an Eclipse....to my Galant? I know alot of the suspension is alike...how about the brakes?
    rotors are a no go. the eclipse is a 5 lug car while the galant is a 4.
    the front brake pads are teh same as the 1g eclipse fwd
    the front calipers are the same as the 2g eclipse calipers fwd.
