will this work
Can u use and eclipse clutch on a galant?????
I need a quick response please.
thanks
Yes, all 1g and 2g eclispse clutches are the same. You can use 2g 7bolts flywheels as well.
then i would have to buy a clutch for a fwd 7 bolt clutch to match up with the flywheel right???
which is better to use with a 4g63t swap, the 7bolt setup or 6 bolt setup??
All 1g/2g clutches are the same. 90-99, FWD/AWD, they are the same. Now the flywheel is 6bolt/7bolt and FWD/AWD specific.
Motor wise the 6bolt will always be stronger and will never crankwalk.
Is this a good setup for my exhuast?
1)EVO VIII exhuast manifold, 2g o2 housing , 2.5 inch bushhur racing downpipe, 14b turbo
2) how good is the pro-clutch kit
