$200 - $250 @ http://www.oem-car-parts.com/
Call local dealers for prices as you would probably need someone to put it in too. But make sure you get a professional opinion on the problem first to be sure it's the pump that's making the noise.
when ever i start up my car, there is a very loud squealing coming from under the hood, i thought it was my ac belt but i looked at it and it is still good, i put my ear next to the powersteering pulley and bingo. it is so loud it hurts my ears, the belt is still good and so is the tension, has anyone had a problem with their powersteering pump? maybe the bearings going bad?? where can i get a new pump if needed?
If it is your ps pump that is bad, check your local junkyard first. Save you some money bro.
