Thread: SAFC-II install??
Showing results 1 to 6 of 6
    SAFC-II install??
    hey just wondering if there is a tutorial on installing an SAFC-II on our cars.. I'm highly debating on getting one and was wondering if the install is difficult, or should I let the pro's do it
    <a href='http://ipods.freepay.com/?r=22659223' target='_blank'>http://ipods.freepay.com/?r=22659223</a>
    b-boy_sky
    Re: SAFC-II install??
    <div class='quotetop'>QUOTE(Stylin_G)</div><div class='quotemain'>hey just wondering if there is a tutorial on installing an SAFC-II on our cars.. I'm highly debating on getting one and was wondering if the install is difficult, or should I let the pro's do it</div>
    You have to soder wires to your ECU. So unless you are comfertable with doing that I would suggest letting a pro do it for you. I had my s-afc first gen installed and dyno tuned for $200....
    Here's the link for a 4 cyl http://www.eclipseforums.org/fortopic30632.html
    Here's the link for a V6 http://www.eclipseforums.org/fortopic107271.html
    I don't have any problem soldering to the ecu, the next thing is finding a dyno to tune it properly, I don't know where one is around the New England area....
    ok I went on the link and it's not working... is there any other guides or tutorials out there than can help me with this install??
    V6 worked great. What a good document. Step by stem, talking about the different rpm voltage fixes as well! I think I'm gonna attempt to get a SAFC-II in the next few weeks, though I dont have the money....this should give me something to play with over the winter....
    Dave
    <img>
    I made a color coded SAFC-II install diagram for the Cali and Fed spec V6. It includes the anti-knock and O2 meter wire diagram too, I need someone to host the pics.
    <img>
