Thread: 6A13 (VR4 Type-V / S) Swap?
Showing results 1 to 20 of 24
    EdLoRPI
    Hi all, I'm a member of Club3G and this post came to my attention:
    http://www.eclipseforums.org/showthread.ph...&threadid=68253
    It's about a company that seems to be able to do the engine swap from a Galant VR4 TT into your type Galants as well as our 3rd Gen Eclipses. Does anyone here know anything more about the JDM VR4 TT and the possibility of a successful swap for our cars? Thanks all. Apologies if you guys already know about this one. Just thought you might also benefit.
    -Ed
    its not as easy as u think. i posted on club 3g
    EdLoRPI
    Nothing is ever as easy as it seems, I know - but how do you know it rotates in a different direction? As far as AWD - not a big deal, just go with the the VR4's tranny so long as the mounts are in the same place. Thanks!
    -Ed
    Senior TGC Member
    2,175
    With enough money all things are possible...
    09-22-2002
    Kissimmee, FL
    1,495
    Man i looked into that shit 3 times already when i blew my motor the first time, and to do it ur easily lookin close to $10k plus just to get that shit out here not including install..and like Pinoy said reverse rotation, that shit will not be easy.. Then even if u pull the tranny to compensate for the reverse rotation that shit will be dumb expensive 2.. IF any of u guyz out there pull this off, i give u mounds of credit cuz this swap would be totally sick
    EdLoRPI
    ...looking into it - and I think Pinoy said on Club3G that the engine goes in the same direction (look at the pix). We'll see if it can be pulled off
    Nick VR4
    Quote Originally Posted by EdLoRPI
    -Ed
    More $$$$$$$ to set up the AWD from the Transmission
    EdLoRPI
    Haha - oops, I realize I posted it wasn't a big deal - I meant it wasn't a big deal whether you get the AWD or not (of course, better to get it)...even in FWD, it should deliver some serious power.
    EdLoRPI
    AWD isn't necessarily a must...of course, it's a huge bonus. As for the AYC and ATC, I'm not sure how those systems are tied into the drivetrain. What I really need are chassis comparisons between the 8G US Spec Galant, 3G Eclipse and the 8G JDM VR4 Galant. So...anyone know anyone in Japan ?
    chibisak
    if u have a Galant then u might have a Problem
    if u have a eclipse, then u are luck out.
    if AT then thats mean u have the INVECS-II but old version
    if MT then is same as VR-G
    model code is
    4A3A <-- Galant i4
    4A5A <-- Galant V6 if my memory is right
    8GJDM VR4 have 2 version,
    1- MT 5 Speed
    2 AT 5 Speed with INVECS-II so if u have a to wait then u should be easy to get those from a EVO7 come out since the AYC, ATC and INVECS-II can get from there the tanny will work as well then u will think should u swap a EVO7 4G63T or 6G13TT.
    4G63T smaller and lighter but MAX tune is around 600-650HP dun count the NOS thing ok
    6G13TT which is same as the 3KGTVR4 b4, MAX can run about 700-750HP both count FULL engine and body tune.
    which u want is ur choice but AWD in this case is need since if u stick with FWD probably dangerous. but all the above i said is doesnt count any money in it, how much is cost i dunno, but since i get know ppl in TGC Japan and HK. these are the info i know of i hope it helps
    -Ed
    Different Chassis so the mounts are different and would have to be custom. meaning $$$$$$
    Quote Originally Posted by chibisak
    model code is
    4A3A <-- Galant i4
    1- MT 5 Speed
    The 3kGT VR4 in the USA at least never used the 6G13TT it uses the 6G72TT big difference in the motor. The 3kGT has a 3.0L Twin Turbo motor versus a 2.5L V6 Twin Turbo motor in the VR4 Galant.
    As for our US Galants good luck trying to fit that in our cars as a direct fit the chassis is different.
    I'm surprised you guys forgot that seeing as NOT SINGLE JDM BODY KIT fits direct on the USDM Galant.
    ESdriver00
    Just finished reading that thread on the 3G forum. Damn very interesting points, IMO the conclusion is you would save money now and in the future(in case you need parts) to just stick with a domestic engine and either turbo or supercharge it, and you know upgrade the tranny and other internal parts. I've came up with that not only because of the money difference but about the amount of power that I would get going either way.
    Honestly guys, I agree with shane 110 % 6grand in a GALANT..are you serious? A cheaper more effective thought I got was getting a front clip of a 1g gst eclipse (2000) Then pay very lil to have the bottom two mounts moved over and move everything over..motor and tranny...total estimated cost lil over 3500. The ability to pop the hood to show it off and make jaws drop..priceless. To my knowledge (very lil) a few people on this forum have the balls and pockets to go through with this..shane, ak1 craig for a few Yea Im getting on that list. the hype of getting that 6a12 or whatever is pointless...gawd forbid you wreck your car..then what? 7grand more? There is no point in spending 10 grand on a garage queen lol if you want high triple digit speed..get a damn bike 750 or more...
    Yea I have never went on and on but Im really tired of people asking my two cents on shit they will NEVER do...oh yea if your galant ISNT in your name you cant do anything to it...cause your keys can be taken the next day when you get a D on your report card!
    09-22-2002
    Kissimmee, FL
    1,495
    Quote Originally Posted by Mante
    I agree on that point too.. Most of the guyz in here who probably do have pockets deep enough to even consider this, i dont know if we would consider this.. Just think about it for a second... ur looking at least $10g's just import the motor ova here... install with custom motor mounts and rebuild of the the housing to cure the monsterous power issue at least $3-4g's, then u got tranny and if ur gonna do it right swappin that shit out, and finding something to hold the power is another issue within itself.. I thought about it, when i got all the numbers together i was lookin at close to $15g's, if not more.. The only way i would think about doing it now, is it i won PowerBall or something..lol..
    Preach on, and keep sprayin
    Nick VR4
    another issue is
    VR4's and Evo's need servicing every 4500 miles
    that includes the AYC fluid etc every 9000
    You cannot drain and refill yourself as you have to have the Mitsubishi diagnostic machine (MUT II) because of the need to activate the AYC pump if doing a complete service.
    Parts are not cheap believe me a 4500 mile service is around $350+
    09-22-2002
    Kissimmee, FL
    1,495
    See thats another reason why it wouldnt be money oriented to do this swap every 4500 miles and $350+ out ur pocket.. shit thats breakin a niggaz whole check..
    yea now that I found the front clip for next to nothing time to get to work.
    Behind YA! (NY)
    727
    most people wouldnt do anything of this magnitude. id say its worth it to me caus there realy isint any other car i would want in the market right now might get a older rx7 or a 2000 imprezza rs as a second car while the galant gets worked over this year and the next.. but to me id say its definately worth it but to a lot of people it isint if you truly like this car and want it for the long run id say go for it but if your saving for somethign else would advise against it caus thats just blowin ur money away...
    - Atba
