It all comes out. But you have to take out the battery to take out one part. Just look closer for all the screws/bolts. I think there was two pieces that I could not take appart, but I was taking them both out anyway, so I didn't bother with it.
Ok just got my filter/mas adapter in. But i have a question about taking off the stock filter box. Ok i got the two 2 bolts that actually hold in on (the one infront and the one attached to the wheel well thing) But i cant get the last of the 4 bolt that are attached to the MAS. When looking at the engine in front, i cant get the one that is on the bottom and to the right. U know.
Also i noticed that the box extends underneath the MAS section. Does this remove also. I htink it does right. ANd also there a section that is attached the the box located between the battery, fusebox and the left fender. Does this peice stay?
Is there any helpful hints that can make this easier and to get that last "Hidden" bolt to the MAS?? Thanks
If you just have the filter/MAS adapter setup, it would be benificial for you NOT to remove that part behind the fusebox/battery/left fender. This will blow cool air at your new filter
Honestly i has been to long for me to remember how to take out the air box, I do know I did not have to remove the battery though.
Good luck bro!
yeah thats what i thought about the piece behind the battery. I guess i'll figure it out.....did you have any trouble getting all the bolts attached to the MAS?? There just one that is sandwiched in a small area i just dont know how to get to it. Thanks for the help
For a couple of those bolts I recall that I used an extension on my socket wrench. 8 inches should do it. Doesn't hurt to practice your Yoga skills either.
BTW, I have a WeaponR intake tube for sale if anyone wants it, gold-ish color (w/decal!) PM me if your interested.
Take out the whole intake (from air box to the rubber pipe that connects to the TB)
This will allow you to get to the screws on the MAS.
Plus it will be tons easier to work with your intake system.
you can just leave it hanging. uhm you might wanna check the filter from time to time to make sure it on there tight. the pipe is flexible. uhm you can amke some kinda bracket, use the bolt holes for the MAS adaptor and MAS to hold the bracket in and then find a place to bolt the other side in, or maybe bolt it up to the stb or somethingOriginally Posted by BLsGalant97
hey seth i cant see the pic you just posted
well me being a mod with super mod powers, i got the url for u, i couldn't see it either...Originally Posted by BLsGalant97
http://community.webshots.com/storage/1/v3...35TAYrib_ph.jpg
mwhah well me being the *super* stud that i am(plus I am special) uploaded it to my imagestation account b/c i forgot webshots does not do remote hosts
Thanks dudes, you guys were a big help. Im gonna go find some brackets tommorrow and whip up my little ghetto engine mod. HA. Id probably be huddled in some ditchright now if it wasnt for you 2 galant moding studs.lol
Thanks again
hey seth.. how does that home depot 4-3 reducer hit on the back of the
MAS on the oval part? does it fit snug? or do you have to clamp that siht down like a mo fo...just wondering cause i have a regular 3-2 reducer and it looks like its about to snap. get back at me. thanx
my old intake.. i have the same setup except its a Cold Air Intake now.
its too big so you have to do a lot of tightening...a 3.5"to 3" adaptor would work best, but they did not have any at Home Depot. oh well this works just as well
