Thread: Is this 20 hp exhaust mod real
Showing results 1 to 6 of 6
    MitGalant
    there seems to be a recent rise in all these bull shit mods on ebay..
    its just another resistor...
    Supernova
    <div class='quotetop'>QUOTE(MrDomu)</div><div class='quotemain'>
    ESV6 stock is 195 HP
    </div>
    Just wondering, what is the HP of stock i4 ES?
    cdaw2001ES
    140 HP
    EsRacer
    BS!!!
    cdaw2001ES
    From Mitsubishishicars.com
    Engine Type: Inline-4
    Engine Block: Cast Iron
    Cylinder Head: Aluminum Alloy
    Displacement (liters): 2.4
    Horsepower @rpm (SAE net): 140@5500
    Torque (lb-ft @ rpm): 155@4000
    Redline (rpm): 6000
    Bore and Stroke (mm): 86.5x100.0
    Compression Ratio: 9.0:1
    Valvetrain: SOHC 16-Valve
    Multi-Port Fuel Injection
