Thread: Engine Swap Help
Showing results 1 to 5 of 5
    B176969
    Engine Swap Help
    ok i have a SOHC 4g63 and i want to put a DOHC 4g63. will it match up or am i going to have to change stuff and if so what would i have to change?
    Re: Engine Swap Help
    <div class='quotetop'>QUOTE(B176969)</div><div class='quotemain'>ok i have a SOHC 4g63 and i want to put a DOHC 4g63. will it match up or am i going to have to change stuff and if so what would i have to change?</div>
    not worth it.
    youll need an entirely new underhood wiring harness, the DOHC computer, and a few other things.
    the engine WILL bolt up, but trust me, its not worth it in the slightest. youll be nickle and dimed to death by little things.
    Hey Manybrews, do you know where I can get a motor for my 92 G. I need lifters, A/C compressor...just to name a few things. Any help will do. Thanks, Ed
    B176969
    well i went ahead with the engine swap. I got the SOHC. but it is like a hopped up version i guess you cuold say. so thanks for replying and helping me out.
    West Palm Beach, Fl
    589
    Moved tob Performance Modifications for the 6g
    Chris
    2004 Mazda 3i; bought 7/2/04
    98 Galant ES; Sold 6/30/04
