Thread: teflon clutch line already failed before i put it in......
Showing results 1 to 20 of 31
    12-17-2002
    Sherman Oaks, California
    4,304
    so i got the aeroquip parts today (http://img39.exs.cx/my.php?loc=img39&image...le_aeroquip.jpg) and i put them onto the teflon steel braided line, and i'm already screwing shit up. i put both ends on, used thread sealer, and tightened them down. good to go, i thought. i put my mouth on one end, blew real hard, and put my thumb on the other really tight, and I can hear air leaking out from the flared part of the fitting. what the hell did i do wrong?
    http://socallifestyle.com/
    1994 Galant GS 5spd
    brandon
    If you think you had everything nice and sealed, maybe you got a bad fitting. How many layers of tape did you use?
    12-17-2002
    4,304
    actually, i'm a moron. when i was "testing" it, by blowing air in it (so ghetto ) i wasn't pulling the fittings out, to simulate the male-to-male -3an fittings being in there. i just re-tested it last night and it worked 100%. i'm a moron. delete this thread to save me some humility
    1994 Galant GS 5spd
    Quote Originally Posted by peanotation
    Yes, make sure you blow the male end!!! hahahahhhahahahahahhahahah, ok, I'm a loser. :cry:
    <img>
    Livn2sk8
    Hey peano...I just got mine today...still waiting on the Earls parts from a different store....summit racing is very quick and reliable.
    I'm just running straight from the master, to the slave....but, do you have any instructions on how to install the fittings to the teflon line? Sorry, but, i've never used this before.
    Thanks!
    12-17-2002
    4,304
    no problem, i already have the pics ready for the soon-to-be-written tutorial
    what you have is 5 parts total. the SS teflon line, 2 -3an aeroquip straight female hose fittings, and two earl -3an male to male fittings, with one end convex and one end convave.
    you want to take your teflone line, and cut back the metal "sheathing" about 1/4-1/2" an inch. this will expose the actual plastic teflon line. slip the brass fitting (pictured above) onto the end of the newly circumsized line (har har). then slide that end with the brass condom (HA HA) on that penis looking piece all the way on the right side of the pic. THEN, slide that piece all the way on the left over the brass/penis piece combo. then screw it on, and use some thread sealer.
    after a few turns it will start to get pretty tough. this is good, its compressing the brass fitting to make a perfect seal over the teflon line. use wrenches and get the two pieces flush. you obviously have to put the left piece on first so you can slide it over the brass/penis combo.
    finished:
    1994 Galant GS 5spd
    08-23-2004
    Chaska, Minnesota
    1,370
    Quote Originally Posted by ChikagoGTZ
    lmfao!! i just see/hear stewie saying that one, and brian just looking at him shaking his head.
    Livn2sk8
    Hmmm.....interesting....so far every tutorial I've read....says NOT to cut back the braids.....but you say to do it? I dunno....
    do it man... do it, DO IT.... ... nice job on the tutorial peano...
    uhhhh...... Whats a 9g???
    I didnt cut mine back, but I have not tested mine yet. I need to go buy some Dot 4/5 and test it. I will let you guys know how it went.
    Even with my -8AN fuel lines, I did not cut the braid back at all.
    12-17-2002
    4,304
    it doesn't really matter. if you cut it back, it allows for a more secure clamp in my mind, cause it can chomp down on the thick plastic line. if you don't cut it back, it can't get a good seal cause of the metal threads. in my mind, it would be like putting your valve cover on with toothpics sticking out from underneat. not a very good seal.
    i mean, whatever metal you cut back, is strictly reinforced by the aeroquip female fitting, so it's not like you have inches of line that's "exposed".
    1994 Galant GS 5spd
    12-17-2002
    4,304
    ok, well that was depressing. i got my EARL 581531 -3an male-to-male adapters today, and they dont' work, because the male ends that screw into the slave/master arn't long enough, so there isn't a seal of any kind. i'm not sure if the 581531 EARL adapters will work for anyone, but they sure as hell didn't work for me. you need ones with longer concaved ends.
    the ones i got is the one on the right, the ones you need is the one on the left
    http://img39.exs.cx/my.php?loc=img39&image...ls_compared.jpg
    edit: ok, summit DOES have these parts in stock, they just don't say so on the website. i just ordered 2 EARL'S 581533 ($28.33 total :? )
    comparison chart from holley
    http://www.holley.com/HiOctn/ProdLine/Prod...PPA/592032.html
    1994 Galant GS 5spd
    I ordered one set of the Earls and banjoed the slave cylinder.
    Livn2sk8
    That's what i'm doing too....banjo...that is...
    Dark7GHawk
    Once you get this done, lemme know what parts fit the best, and how you specifically ran the line. My car is sitting in the garage right now, unable to move due to a broken hardline from accumulator to slave. I wanna know how this works and if it prevents anymore problems.
    Any idea what would cause my car to break 5 hardlines in a row?
    Livn2sk8
    Hey dark....I talked to a guy who knows alot about clutches and trannys...and he told me to check my tranny mounts....because if the tranny jumps/shifts too much..that steel line to the slave...will just crack/break. I have also been through ALOT of those lines in the past few months, which is why i'm going with the teflon...more flex, and holds more pressure.
    Dark7GHawk
    Thats a thought, I guess my mounts could be bad. Will have to check those. Replacing those at home isn't that hard either.
    12-17-2002
    4,304
    hmm, i guess i was wrong about one part. you want to cut back just a tiny bit of the metal sheathing so you can fit the compression fitting over it, but when you go to tighten up the aeroquip fitting, you want the "waist" of it to be squeezing the metal sheath on top of the plastic on top of the compression fitting. i realize that makes no sense, but basically, you want to have metal sheathing under the part that clamps the hose together. try to not cut any if you can, but it'll be hard to get the brass fitting in there.
    1994 Galant GS 5spd
    12-17-2002
    4,304
    well it's been about 1,500 miles with the tranny in, and just wanted to say that i'm having a very minor leak on the teflon line. it's the end that goes into the slave, so it's a bitch to get to, but the master cylinder reservoir has gone down about 1/2" so it's minor enough to keep driving it. i think eventually i'll have to re-do that compression fitting though. so i guess the moral is, use a thread and compression sealant to ensure a better fit
    1994 Galant GS 5spd
    01-10-2003
    BROOKLYN nYC
    1,570
    stupid question but.. how much did it cost you for the parts to make the clutch line..Those stupid an fittings arent cheap, neither is braided line. If I were to buy the parts through summit it would cost me a hell of a lot more then it would to buy it ready made from RRE.
    Rob
    rIp 97 Galant
    starting over.
    90 Talon
