Thread: i'm building a motor this winter......
Showing results 1 to 20 of 20
    8G_GTZ
    i want to know if there is ANYTHING down to the nuts and bolts that I need on this list. this is just so I don't forget anything major while on the job. the list is mostly based on a member who had a post about building his '64 and also turboing. so here is a combo of his and mine but i'm creating an all motor application so you know:
    2G DOHC HEAD 2.0L(still doing head swap this winter)
    PORTED(save for turbo)
    5-ANGLE VALVE JOB(save for turbo)
    CROWER CAMS(save for turbo)
    AEM CAM GEARS(save for turbo)
    GASKET MATCHED PORTS(save for turbo)
    4G64 BLOCK
    HOT TANKED/CLEANED
    PORT/POLISH
    BORED .020 OVER
    8.5:1 ROSS PISTONS BORED OVER .020<--so stock?
    CROWER RODS (4G63 7 BOLT 2G)
    ARP HEAD STUDS (11MM)
    AUTOMETER OIL TEMP. GAUGE
    AUTOMETER OIL PRESS. GAUGE
    FUEL MANAGEMENT
    660 DENSO INJECTORS(save for turbo)
    190 WALBRO FUEL PUMP
    APEXi SAFC II
    AUTOMETER A/F RATIO GAUGE
    UGO WIDEBAND O2 SENSOR
    BRAIDED FUEL LINES
    EXHAUST/INTAKE
    CUSTOM COLD AIR INTAKE
    OBX DTM STYLE MUFFLER
    OBX HIGH FLOW CAT
    4G63 N/A HEADER
    4G63 N/A DOWNPIPE
    AUTOMETER EGT GAUGE
    IGNITION
    NGK SPARK PLUGS
    MSD INGNITION
    MSD BLASTER COIL
    ACCEL SPARK PLUG WIRES (8MM)
    97/98 ALTENATOR
    09-23-2002
    Port St. Lucie, FL
    666
    Well whenever you get the answer to all of this.... lets make this into a tutorial
    when is we gon be free????
    Re: i'm building a motor this winter......
    Quote Originally Posted by shogun7g
    4G63 N/A HEADER
    4G63 N/A DOWNPIPE
    Not going to turbo it? If not, you need to make several changes to your list. For example, the injectors and fuel pump would be a waste of money. Also, gasket matching the ports on the head would cause a decrease in power unless you are running in excess of 20 psi of boost. The ARP head studs are probably not necessary on a N/A motor. Also, a higher compression ratio than 8.5:1 would be a better choice in a non-turbo engine. If you're going to do all this work, why not turbo it?
    8G_GTZ
    no turbo....all motor. not even slightly larger injectors though? thanks again.
    steve
    if you had a bigger bore maybe larger injectors...but yeah...definitely higher compression....i dont know what your compression is stock...but raise it for an n/a motor....
    President Team DNA IL Chapter
    [email protected]
    www.dnaracing.net
    09-23-2002
    Port St. Lucie, FL
    666
    since your planning on going n/a, you might want to try and get ahold of dukeplaya aka n/a SOHC 4g64 god :shock:
    8G_GTZ
    what compression do you think then
    stock is 9.3 or 9.5:1, not too sure. You could just shave the head to raise the compression ratio. Why no turbo?
    12-17-2002
    Sherman Oaks, California
    4,304
    if you're not going to go turbo (dumb) and go all motor, get higher compression pistons that stock (duh). also, let me know what body organs you're selling to pay for all of this
    http://socallifestyle.com/
    1994 Galant GS 5spd
    brandon
    If you're dead set on staying N/A, good for you.
    Definitely PM dukeplaya31 if you have specific questions. He'll be able to answer most if not all.
    If you want power, go turbo. No questions asked. You will be disappointed if you do not. Stock compression is 9.5:1 so go with higher comp pistons then that if you are staying NA, but 8.5:1 is fine for turbo. Why not turbo? Your spending all this money to build your motor to handle power and you wont ever take advantage of it being NA. Buy a $550 EVO3 16g and supporting mods and your set.
    neh i dont think he'll stay N/A....the good thing to do is over-builed ur engine and whenever u wanna go turbo, u wont have to worry bout if ur engine can handle it
    8G_GTZ
    Quote Originally Posted by josh_877
    that's exactly why guys....
    i want to run this way for a while, see what happens... then when more funding comes in over the summer(summer after graduation-yaaaay!!), I will then go turbo if that is what my mind is set on. I really want to make a car, or Galant for that matter, that everyone will remember and would like to be in a few magazines and shit like that. Of course, that's a long time from now. but you guys are great helping me along the way. thanks
    keep the info comin on that list.....
    steve
    yea i knew it, im always right!
    Well man alls I can say is dont over due it. Dont spend $300 on 660 injectors that you do not need. I wouldnt even buy the cam or cam gears untill you are turbo. Build up the bottum end and run a stock head untill you are ready to turbo. That way you do not spend what is not needed. The bottum end is where it needs to be the strongest anyway. You do not even need to build the head untill you are in the high 400+whp range. Also, you will probably benifit more from a 2g turbo head then a 1g head if you stay NA.
    If I were you, I would build the bottum end, aftermarket rods and pistons, head studs, still hot tank the block and bore over .020, but just run a stock head for now. Grab the 660cc injectors a medium/small turbo, 2g manifold and an aftermarket FMIC/piping kit. You would be much MUCH happier to do this instead of building the whole engine and just running NA.
    09-23-2002
    Port St. Lucie, FL
    666
    That would be going outta your way though, wouldn't it?
    How so? just run a stock head till you have to change the timing belt(1 year or so) and by that time he would have most of the necisarry bolt ons and recovered financially and be able to afford a nice built head.
    09-23-2002
    Port St. Lucie, FL
    666
    my bad seth... i posted like a sec after you did, haha...
    yea i still say to over-build the engine, just be smart about it, dont waste ur money on unnecessary parts.
    As others have said, build the bottom end and turbo it. If you use stock parts for the turbo, you should be able to do it cheap. Then upgrade from there. You'll gain a lot more power by doing that, than you would by staying N/A.
    If you do everything on your list, you are less than $1,000 away from being turbocharged. Considering that your list has about $6,000.00 worth of parts and machine work on it, what's another grand?
    I'm not trying to talk you into changing your plans, just want you to look at how close to being turboed you would be.
