check the fuse and make sure the harness is plugged into the CC switch.
i just noticed that my cruise control doesnt work anymore...wtf?!
i cant drive without cc....I NEED IT!
i checked the cables, they all good.
help me.
Yah most likely a fuse.
Speaking of CC, yours still works with the swap done, correct Peano?
<div class='quotetop'>QUOTE(seth98esT)</div><div class='quotemain'>Yah most likely a fuse.
Speaking of CC, yours still works with the swap done, correct Peano?</div>
no, but i'm 99% sure its related to the speedometer still not working
IIRC Cruise control has a lot of lines that run to the TCU.. since you pulled the TCU out Cruise control computer is probably not getting the info it wants from the TCU.
Rob
rIp 97 Galant
starting over.
90 Talon
<div class='quotetop'>QUOTE(JiP)</div><div class='quotemain'>IIRC Cruise control has a lot of lines that run to the TCU.. since you pulled the TCU out Cruise control computer is probably not getting the info it wants from the TCU.</div>
tcu is still in the car, but i wonder since it's not getting the same information it was before if it'll just shit a brick and not work with the cruise control. i'd really like to get my speed sensor working so i can see if the cruise control works after that.
