Thread: DIY TUTORIAL: Auto to 5spd swap for 7G
Showing results 21 to 40 of 57
    I had that same problem with the starter not engaging the flywheel, but this was when I was using my auto starter. I installed a 5spd starter(from a 95 I think) and it engages now. You could always schim the starter gear so it sticks out farther.
    Member
    FT. Lauderdale, FL
    285
    well i found the problem..... it was 2 things: i was sold the wrong starter and flywheel..... the flywheel is from an 2g AWD i ordered a 2g turbo FWD.... and the starter was my fault i took what they gave me, i realized it was wrong when i was under the hood....lol
    "One good thing about music, when it hits you, you feel no pain." - Bob Marley
    12-17-2002
    Sherman Oaks, California
    4,304
    how do the FWD and AWD flywheels differ?
    http://socallifestyle.com/
    1994 Galant GS 5spd
    Member
    FT. Lauderdale, FL
    285
    the AWD flywheel is smaller in diameter....
    best part about this whole thing is that i return it because its been 2 months..... i asked for a FWD he typed up for an AWD.... paper work says AWD.... but i know what i asked for...
    I just realized I bought a 2g turbo AWD flywheel, damn it has to have been over 3 months ago. ANY problems to run a AWD flywheel? would the flywheel make a difference??
    Its smaller in diameter therefore you would either have to mod the stock starter or somehow use an awd starter. Not even sure if that would work, just sell it and buy a FWD flywheel, make things easy on yourself
    <div class='quotetop'>QUOTE(seth98esT)</div><div class='quotemain'>Its smaller in diameter therefore you would either have to mod the stock starter or somehow use an awd starter. Ā*Not even sure if that would work, just sell it and buy a FWD flywheel, make things easy on yourself </div>
    something I did not want to hear :cry: . any suggestions of flywheels?
    12-17-2002
    4,304
    i have the act street-lite. pretty fucking solid. get the fidanza, more expensive, but 3-4 pounds lighter. everyone loves it.
    1994 Galant GS 5spd
    Member
    FT. Lauderdale, FL
    285
    the AWD flywheel is smaller in diameter the starter is not going to be able to catch the flywheel to turn it.....
    yeah i got the findaza flywheel.. 8lbs... real light.... but theres only one down fall to this flywheel, your will decelerate quietly..... i love it.... you'll just have to learn a new way of driving....
    wow great job on the tutorial.... i felt like i was there....
    uhhhh...... Whats a 9g???
    polo13199
    does anybody know of anywhere in NY that will do the auto to 5spd swap. I donĀ“t have the space tools or the room to do it myself. Although I would love to but. I can buy the parts if need be and have someone else do it if anyone knows where i can get it done.
    brandon
    <div class='quotetop'>QUOTE(polo13199)</div><div class='quotemain'>does anybody know of anywhere in NY that will do the auto to 5spd swap. I donĀ“t have the space tools or the room to do it myself. Although I would love to but. I can buy the parts if need be and have someone else do it if anyone knows where i can get it done.</div>
    DO NOT multiple post.
    05-25-2006
    New York City
    1,028
    Thought I might add this since people are having problems when using old shift balls and forks. If your shift fork doesn't look like this you need to adjust it with shims or you will have problems with your clutch.
    and this is the pic to adjust the pedal
    2000 Galant ES = Daily Driver
    Proto
    Back from the dead. Seth had a trick with cross member in when putting in the 5 speed, I did this and it worked out well.
    12-17-2002
    4,304
    UPDATE: reverse wires added to tutorial at the very end.
    1994 Galant GS 5spd
    Bronx NYC (reppin)
    3,489
    nice!
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
    Kansas City, MO
    1,244
    Quote Originally Posted by peanotation View Post
    what do you connect them too!!!
    Kansas City, MO
    1,244
    never mind :oops:
  19. #39
    The sensor on the top front of the trans. Would have to have the original pigtail/connector or use generic connectors from autozone.
  20. #40
    Kansas City, MO
    1,244
    Quote Originally Posted by seth98esT View Post
    i didn't notice it the first time i looked at the pic, but it's in the bottom right corner of the pic.
