Thread: confirming a fact from another thread
Showing results 1 to 4 of 4
    Member
    07-20-2003
    Albany, NY ...CAP CITY!!!
    238
    In another lowering spring thread, it was said that 1g Eclipse lowering springs will fit our 6g's.... I believe the person who said it earlier, but I just wanna confirm this fact before I spend the money.
    Also, if this fact is true, and anyone has $94.00 and wants to lower their 6g, check out this link, just scroll down to mitsubishi (this link is also from another thread)
    http://www.speedstash.com/springs.html
    00' Diamante LS
    93' Galant n/a (gave to my bro)
    Member
    07-20-2003
    238
    por favor, does anyone have any info on this...
    (en espanol)
    si usted tiene informacion, dimelo por favor ...
    00' Diamante LS
    Galant-UNIT(sur_texas)
    kien sabe
    ken inn
    yah, they fit, BUT, and this is only from my vr4, the front galant spring is about 1" longer, and the rear springs are 2.2" longer, so the car might sit lower in the rear. you will get a much better fit using the rear springs from a bmw E34 5 series. also, the t/e/l front strut spring perch is slightly lower.
