Member
So, y'all suggest I go with something like this:
http://www.extremepsi.com/store/customer/p...&cat=506&page=1
It's only a couple hundred dollars more than the Evo III 16g. I hope the torque of the 2.4 will keep lag to a minimum with the 60 trim.
Thanks fellas, for the info.
The PTE 60trim is dubbed the "Pump gas King" It is a very good turbo. If you are going to build your motor to handle 20-30lbs of boost, it would be a good choice turbo
