Just an FYI, the pinout locations should be the same as the '98.
I find it odd your dealerships can't at least FIND the pinouts, never mind print them.
people i have gone to 2 dealers and none of them can find nor print the ECU pinouts for the car... i need this.... YES i have done the search... but all i get is the 98 spec.... can anyone help?..... im not one to bother
- Eddy
"One good thing about music, when it hits you, you feel no pain." - Bob Marley
go to the library. i was the same as you. go there and they have or should have all of the Chilton's in there.
steve
alright i have 20 dealers in the southeast area of the country... and nothing
well with all the info on here about the ECU.... everything was wrong... i cant locate the airflow sensor pin, nor the RPM pin.....
i dont know if this makes a difference but when i first bought the car i noticed that everywhere in the car it said DSM.... i have seen a few members cars and theres says mitsubishi... like in the door jam, and under the hood (on the firewall).... ?
i guess i have a galant made by DSM...
i found em from when i went to get em. do you have a fax? if not let me know, i'll scan em.
steve
thank you sir.... my office fax is 954 748 7625... make it attention Eddy
<div class='quotetop'>QUOTE(ViciousLord)</div><div class='quotemain'>thank you sir.... my office fax is 954 748 7625... make it attention Eddy</div>
Right now?
if you can
3 pgs sent. how did they turn out?
steve
i didnt get the fax...
are you serious? i sent all of them to the same number you gave me. of course i had to dial 1 before, but it said it went through?
steve
very tru..
anyone? i need this for saturday...
is it possible to have a 1g style ECU in a 95 galant?
i only ask because all the ECU diagrams i find for the 95 galant are 32 pins across and my ECU is only 26 across
thanks...
i still need this guys...
anyone?
You could run a 1g ECU in your car but it would be a lot of wiring.
my ECU is 26 pins across just like the 1g..... according to every diagram i have it is supposed to have 32 pins across like the 2g..... explain....
