Thread: Turbo Sizing Offer by Scootin
Showing results 1 to 14 of 14
    Well, since it seems to me that many people dispute the sizing for turbochargers on the various Mitsu engines, I've decided to try and be useful. If you want to figure out what turbo is best for your application, post up your engine size, performance modifications (to the extent of "heavy engine mods" or "not so heavy engine mods"), number of cylinders, and amount of boost you want to run. It would help greatly if you post up a few ideas for which turbo you want to run so it will be easier on me to search for compressor maps. Also, post up your AIM s/n so I can get a hold of you if I need to ask you some questions.
    btw, if there are a bunch of posts in here, look through before asking me to size your turbo to make sure someone didn't already ask for the same sizing. Eventually, I'll put together a list that will have the various engines and boost pressures and the turbo you should run for each. Hope this helps somebody.
    Mindless
    Just to help.
    How to read compressor maps:
    http://www.turbocalculator.com/how-to-read.html
    Turbocharger compression calculations:
    http://www.gnttype.org/techarea/turbo/turboflow.html
    Compressor maps for some Garrett turbos:
    http://www.turbocalculator.com/garrett.html
    8ggalant
    good idea scootin
    This ain't exactly Quantum Mechanics....
    <img>
    Just reading, is this a typo?
    <div class='quotetop'>QUOTE</div><div class='quotemain'>Example: a boost gauge reads 0 psi before it is hooked up. Hook it up, boost the car, and it reads 17 psi. 17 psi is the gauge pressure, the absolute pressure at sea level is 14.7 + 19 = 33.7.</div>
    Shouldnt it be 14.7 + 17 = 31.7? WHere did the 19 suddenly appear from?
    Mindless
    <div class='quotetop'>QUOTE(seth98esT)</div><div class='quotemain'>Just reading, is this a typo?
    Shouldnt it be 14.7 + 17 = 31.7? WHere did the 19 suddenly appear from?</div>
    typo
    ChikagoGTZ, This isn't off topic. ether contribute to the thread or don't comment. The new rules are in effect.
    Wes
    Another fine post brought to you By:
    The Manâ„¢
    Search the boards first please!
    8G_GTZ
    4G64(2.4L 4cyl)--7-9lbs--with intake, plugs, wires, high flow cat, muffler
    4G64/63 hybrid(2.4L 4cyl)--7-9lbs--with same mods above
    fully built 64/63(2.4L 4cyl)--10-16lbs, possibly more--hybrid with same mods
    should help most people there
    steve
    <div class='quotetop'>QUOTE(shogun7g)</div><div class='quotemain'>4G64(2.4L 4cyl)--7-9lbs--with intake, plugs, wires, high flow cat, muffler
    4G64/63 hybrid(2.0L 4cyl)--7-9lbs--with same mods above
    fully built 64/63(2.0L 4cyl)--10-16lbs, possibly more--hybrid with same mods
    steve</div>
    Give me a day or two and I'll run those numbers through.
    And yeah, Chikago, I'm fully aware it's not quantum mechanics, but it's beyond the talent range of most people on TGC and I figured I would try to help out.
    <div class='quotetop'>QUOTE(scootinintegra)</div><div class='quotemain'><div class='quotetop'>QUOTE(shogun7g)</div><div class='quotemain'>4G64(2.4L 4cyl)--7-9lbs--with intake, plugs, wires, high flow cat, muffler
    steve</div>
    And yeah, Chikago, I'm fully aware it's not quantum mechanics, but it's beyond the talent range of most people on TGC and I figured I would try to help out.</div>
    I retract my earlier statement Scoot to avoid Wrath of Mod.
    <img>
    8ggalant
    steve</div>
    a 4g64 hybrid motor will have more thatn 2 liters of displacement
    The 4g64/63 hybrid you are talking about is, I assume, a 64 block with 63 head(not 63block with 64 SOHC head lol) which is still 2.4L. Now somebody make a crank/rod/piston combo for a stroker 64 package. That would own.
    8G_GTZ
    <div class='quotetop'>QUOTE(seth98esT)</div><div class='quotemain'>The 4g64/63 hybrid you are talking about is, I assume, a 64 block with 63 head(not 63block with 64 SOHC head lol) which is still 2.4L. Â*Now somebody make a crank/rod/piston combo for a stroker 64 package. Â*That would own.</div>
    that's what your motor is for seth, bring it down fucker!!! lol......that last option on my list is what your motor is for with that head in my basement. TURBO after may!!!
    steve
    Mindless
