1. There are more companies that make a CF hood for your application. There should be about 3-4 if I'm not mistaken.
2. A strut bar should not interfere with the hood. The "skeleton" is molded to the OEM hood skeleton. If any interferences, you may cut it, you might not. It will only weaken it.
3. Depending on how good of a mold it is, you most likely won't need them. Some latches aren't exactly in the correct area, so you may need them.
4. Hood pins are universal. They connect to the radiator support with 2 holes drilled(sometimes not).
5. Most companies should have the holes with the correct thread for the stock bolts.
6. If you take it to a quality shop, they will know how.
7. You can wash it the same as the rest of the car. When you dry it, do not use a bath towel. Use a shamoise or 100% cotton terry cloth. You should wax it often to keep the shine.
