are you sure that it is leaking?? you sure its just not getting overfilled?? just a thought.
i have my stock one. don't really need it. i'd sell it to you for cheap buy shipping to the other side of hte country might give you second thoughts.
with that said, you might want to try the dealer or even the junk yard if you know any. replacement of the tank is pretty easy. disconnect the line that goes from the radiator to the tank and then just pull up on the tank to remove. after that, just drop back in the new tank, connect the line and refill.
they do sell unversal aftermarket ones. i got mine from another member here. its made by weapon-r. it does the job.
