yes, youll need some.
BLOCK PARTS
·6 bolt block bored .020 over
·Eagle Rods
·J&E 9:1 pistons (.020) over
·UR underdrive Crank Pulley
·ARP main bolts
·ARP rod bolts
·Polyeurethene motor mounts
·Balance Shaft Eliminator Kit
·Balanced and bluebprintedr otating assembly
·Clevite Bearings
·Fel-Pro Gaskets
·Cometic HP Head Gasket
CYLINDER HEAD PARTS
·Race ported and polished 1G head
·Decked
·5 angle valve job
·1 mm oversize stainless steel swirl cut valves
·Crower valve spring kit with titanium retainers
·Webcams Race Grind 1(264 intake/274 exhaust)
·ARP head studs
FUEL SYSTEM
·Walbro 225 lph high-pressure fuel pump
·Aero motive fuel pressure regulator
·Fuel Pressure Gauge mounted on rail
·Injector Clinic 750 cc/min ball style fuel injectors
IGNITION
·NGK BPR-7ES plugs
·Accel 8.5 mm wires
INTAKE
·MAS replaced with speed density via Pro-EFI
·HKS Blow off Valve
·Spearco 2-216 Intercooler with custom piping
EXHAUST
·Ported 2G exhaust manifold
·Custom 3" straight through piping w/
·Dynomax Race Magum Bullet muffler
TURBO
·FP 3065
DRIVELINE
·Clutch Masters Stage 5 clutch kit
MANAGEMENT
·Pro-EFI Standalone Fuel Management (Proto-AEM EMS)
·Blitz Dual Solenoid Boost Controller
GAUGES
·Greddy 60 mm peak hold EGT
·Auto meter Oil Pressure
·Auto meter Oil Temperature
·Auto meter Water Temperature
·Auto meter -30 - 0 -30 Boost Gauge
·FJO Wideband O2 Sensor
GOT MONEY ?
<div class='quotetop'>QUOTE(01GalantLSV6)</div><div class='quotemain'>yes, youll need some.</div>
Some? id say 5g's+
But for the money theres
$1
$5
$10
$20
$50
$100
you could use
YES I STILL HAVE MY GALANT!!
