I had that problem at one time. What I did was replace the air filter, spark plugs, and spark plug wires. I havent seen it happened ever since.
but now I have recently noticed that my idle is a little bit higher than usual.
Hi,
Does anyone of you have seen this Problem on your 8G.
while idle, the car suddenly RPM drop to 0 or nearly stop.
or battery seems not enough.
Also while u shift to N , the RPM seems, up down up down around 1-2Krpm a while u doesnt put ur leg in pedal at all.
My car has just CD player for audio and just mod the intake, CAM, pulley, exhaust.
If anyone can tell me whats going on, that will be great.
CHIBISAK
Pearl White 2001 Mitsubishi Galant ES
Injen Race Division CAI System
Denso Iridium Spark Plugs
Magnecor Ignition Wires
Showoff Krypton Series Xenon Headlight Bulbs (H4)
Showoff Krypton Series Xenon Fog Light Bulbs (893)
Clear Corner Lights w/ PIAA Xtreme White Bulbs (1157)
Reverse Indiglo Gauges
Kenwood KDC-MP522 MP3/CD Receiver
Infinity Kappa 652.5i 6.75" Door Speakers
Kicker K693 6x9 Rear Speakers
Brembo Cross-Drilled/Slotted Disc Brakes
Axxis High Performance Brake Pads
i change that while like 25K mile
now is like 45K so dunno should i change it or not ~~ again~~
mine is 99 L4, how about urs
My car likes to boogie while in neutral but that's probably just because the engine is disengaged from the tranny...
did the cable mod as TOC posted
doesnt help still drop on idle
anyone have idea
Clean your throttle body (the automotive equivalent to,"have you tried rebooting your PC?)
Read this link it also belabors the point...
http://www.tgc-forums.com/phpBB2/viewtopic.php?t=3419
