They will work - but could foul prematurely - especially when driving short distances. Those are 1 range colder than stock. What you want for stock replacement is BKR5EIX-11. But, FWIW, on the I4 there is no reason to use the iridium, you'll pretty much get the same performance and better idle on a fresh new set of coppers - either BKR5ES-11 or BKR5E-11 - only difference in the 2 is the E is 'v-powered" - it has a small v-grove on the contact.
J
