Thread: Clunking Metal on Metal/Plastic Noise
Page 2 of 2 FirstFirst 12
Showing results 21 to 30 of 30
  1. #21
    07-20-2003
    Orlando, FL
    3,169
    <div class='quotetop'>QUOTE(SamirDarji)</div><div class='quotemain'>Thank you for the reply. Â*I did some searches but never came across your thread. Â*
    I'm going to remove my pulley in the next few hours and hopefully get down to the Mitsu dealer and get a replacement.
    Did yours completely separate like that or did you have to force it apart?</div>
    My totally seperated...check out the pics on the thread I linked. I have a pic of the center H balancer completely seperated from the belt track pulley.
  2. #22
    07-31-2002
    Bronx NYC (reppin)
    3,489
    That is "Do Not Put Off" problem, get it fixed fast. It is very easy to change if you have the right tools.
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
  3. #23
    Proto
    socket wrench, 12mm socket, 6" extension
  4. #24
    SamirDarji
    <div class='quotetop'>QUOTE(4-G-rim)</div><div class='quotemain'><div class='quotetop'>QUOTE(SamirDarji)</div><div class='quotemain'>Thank you for the reply. Â*I did some searches but never came across your thread. Â*
    My totally seperated...check out the pics on the thread I linked. I have a pic of the center H balancer completely seperated from the belt track pulley.</div>I noticed that. Mine doesn't seem to have done that yet as it is still in one piece and I couldn't get it to wobble when I tried to force it by hand.
    But the car is up on ramps, the belts are off, the pulley is disconnected from the crank. Now I just have to lower the engine a bit to clear that extra 1mm for the pulley to come off. While I was in there, I noticed no oil around the crank, but I did see oil near the filter and part of the pan. I also noticed by side and front motor mounts bushings cracked.
    What I'm really wondering is did Mitsu redesign the part to not fail like that again. I know they redesigned the lifters to eliminate the tick, and I know Nissan improved their parts as well. If Mitsu redesigned it, I'd be inclined to get the factory part. The other route I'm thinking of is an aftermarket pulley that is lighter, yet the same size as stock.
  5. #25
    SamirDarji
    <div class='quotetop'>QUOTE(bronxbombr)</div><div class='quotemain'>That is "Do Not Put Off" problem, get it fixed fast. It is very easy to change if you have the right tools.</div>Most definitely easy. I have the service manual so that's even better. The hardest thing was actually the routing of the belts to remove them. Everything else was a snap. Too bad all cars pulleys aren't like this. The Altima pulley is killer hard to get to.
    Hopefully I'll be up and running by Tuesday.
  6. #26
    SamirDarji
    <div class='quotetop'>QUOTE(Proto)</div><div class='quotemain'>socket wrench, 12mm socket, 6" extension</div>Don't forget the torque wrench. As with all other critical bolts on the car, the crank ones have a torque spec.
  7. #27
    secondgenntrip
    Quote Originally Posted by SamirDarji
    Quote Originally Posted by Proto
    Any idea what the torque spec is for this, sounds like my current problem.
    Thanks
  8. #28
    07-31-2002
    Bronx NYC (reppin)
    3,489
    i'll look and post later.
  9. #29
    spyder97gs
    If they are tightened down well they shouldnt be a problem, more than likely you need a new pulley. They are about $75 from Napa, and high quality at that.
  10. #30
    SamirDarji
    Quote Originally Posted by secondgenntrip
    Thanks
    From off the top of my head, I'd have to say 25ft/lbs. I know it wasn't much. I'll check when I get back home in the next few days.
