initialize the unit,(to reset to defaults) then do the setup again. see if that changes anything. Take a look at the wiring and see whet kind of splicing job they did. Did they use vampire slices or did they solder? In the manual it strongly suggests against usign splices as they can degrade the signal quality. Check their work while your in there, did they tap the correct wires. Did you do the blue wire mod? i would recomend against it, it can screw up your o2 signal. check to make sure the ground wire taps are in the proper order. check the TPS voltage to see where its at. should be less than 1 volt at idle.
check for gas fouled plugs too.
