Thread: Questions for the nitrous gurus on here
Showing results 1 to 4 of 4
    exoticimport2000
    I have a I-4 nad am putting a Zex dry kit on it. I am setting it up for a 50 shot and see alot on the board about Peno and others being experts on nitrous installs on galants. I would like to know any tips on using the nitrous on my I-4 and do and don'ts . Anything will help. THanks in advance.
    02-29-2004
    Orange County(irvine), CA
    638
    im no expert, but i know that the bottle isnt the only thing you need. u need new fuel pump and injectors too, dont know what else.
    12-17-2002
    Sherman Oaks, California
    4,304
    don't put a dry kit on, put a wet kit on. it's not required, but it's a good idea to get a 190 fuel pump and re-wire it. i could go through the list of dos and donts but you can research all that on your own. you'll also need spark plugs 1-2 steps colder than stock, and i think i'm forgetting something.
    do a lot of reading
    http://www.dsmtuners.com/forums/forumdisplay.php?f=11
    http://socallifestyle.com/
    1994 Galant GS 5spd
    01GalantLSV6
    peano is right, if you dont follow those steps you will blow your motor easily 3-5 times faster. peano did those mods and his motor is holding up fine, albeit 58 years old.
