Thread: Cold air intake?
Showing results 1 to 15 of 15
    Supernova
    Cold air intake?
    Yeah, around how much will one run me and about how much HP will one boost me in an i4?
    varies from 50 (homemade) to about 500 (aem, at least the most expensive i seen, i seen aem for cheaper)
    as for hp, im seeing single digits...
    Supernova
    <div class='quotetop'>QUOTE(pinoyesv6)</div><div class='quotemain'>varies from 50 (homemade) to about 500 (aem, at least the most expensive i seen, i seen aem for cheaper)
    as for hp, im seeing single digits...</div>
    Meh... well, does it make the car sound better?
    Senior TGC Member
    2,175
    Depends on how you define better. For my dad if a car could be completely silent that's better. For me, as long as it's ballsy I could go for quiet rather than Civic ripping loud.
    Black2k1GTZ
    $500 for an intake?? What the hell is this made out of??? The most expensive Ive seen for a Galant is like $250...
    Marc :mg:
    2002GALANTes
    I paid 250.00 for my Injen Rd Cai, and i love the way it sounds. I couldn't tell you the hp, i guess from 1 -3 at most.
    Supernova
    <div class='quotetop'>QUOTE(2002GALANTes)</div><div class='quotemain'>I paid 250.00 for my Injen Rd Cai, and i love the way it sounds. I couldn't tell you the hp, i guess from 1 -3 at most.</div>Well, at least it sounds good. The HP can come later I guess...
    Member
    Minneapolis, MN
    130
    <div class='quotetop'>QUOTE(Supernova)</div><div class='quotemain'>
    Meh... well, does it make the car sound better?</div>
    Do the intake mod where you flip over your intake box, then go drive around for awhile and accelerate hard and you will get atleast a better idea of the sound you get.
    Disconnect your negative battery terminal while your doing the mod too, then hook it back up when your done so it will re adjust to getting alot more air now or it might run funny when your start it up from getting too much air and not being used to it
    <div class='quotetop'>QUOTE(Supernova)</div><div class='quotemain'><div class='quotetop'>QUOTE(pinoyesv6)</div><div class='quotemain'>varies from 50 (homemade) to about 500 (aem, at least the most expensive i seen, i seen aem for cheaper)
    most intakes sound the same, air being passed thru a filter then a pipe. if u are familiar with intakes, u should know that sound. if you like it, the its gonna sound better, if u don't then it wont
    Tiller
    I paid $271.50 for my AEM...
    I opted for the polished finish which was $29 more, so it would have only cost me about $245... this was for a V6 though...
    The AEM dynoed at a peak of about 6whp...
    Senior TGC Member
    2,175
    I paid 190 for my AEM CAI, that included overnight shipping.
    Supernova
    Quote Originally Posted by Supernova
    Well, i've never heard what one sounds like. Adn If I have, i don't know it. I'm not that familiar with engins and the stuff you can do to them....
    SILVERES
    about the intake thing i have an short ram injen my question is can i get a cold air extention for it if so how much or not can it be customized thnx o its a v6 if that matters
    Quote Originally Posted by SILVERES
    if you have the eclipse intake, then its just as easy as getting the extension. if you got the galant intake, you have to make up an extension, cut apart some of the injen intake and you should be str8
    Which Eclipse intakes work on a 2000 i4?
    I've got one love in my life. And my girlfriend's learned to live with it. Girlfriends come and go. Your ride is forever.
