Thread: 8G Galant bulb list
Page 1 of 4 1234 LastLast
Showing results 1 to 20 of 66
    09-10-2003
    Charlotte, NC
    4,463
    8G Galant bulb list
    Headlight
    Part number = 9003, H4, HB2
    Parking light
    Part number = 1157A
    Front turn signal
    Part number = 1157A
    Rear turn signal
    Part number = 2057*
    Tail light
    Part number = 2057*
    Stop light
    Part number = 2057*
    High mount stop light
    Part number = 921
    Fog/Driving lights
    Part number = 893#
    License plate
    Part number = 168
    Back up light
    Part number = 1156
    Front side marker
    Part number = 1157A
    Rear side marker
    Part number = 2057*
    Ash tray
    Part number = 74
    Dome light
    Part number = DE3175$
    Step/Courtesy light
    Part number = 158
    Trunk/Cargo area
    Part number = DE3022
    Instrument-general
    Main Cluster Bulb = 158, 168, 194
    * Can substitute a 1157 as both bulbs have double contacts
    #Can substitute H880/892/899/885
    $Can Substitute a 561 for Hyper White or Colored Lights
    Lemme add the JDM's
    H7 Driving light low beam
    H1 Driving Light high beam
    H3 Fog light (old style VR4)
    The Altima
    4,455
    and ba9s for the city light bulb
    Jason - - cofounder of TGCNY
    2001 Galant ES
    Calipso
    Does anyone have the light numbers for the TYC altezzas? 99-03 (8g) of course. :?:
    09-10-2003
    Charlotte, NC
    4,463
    they use the same bulbs
    Quote Originally Posted by Serstylz2
    no they don't.
    which bulb are you looking for? i know some of the numbers are posted somewhere on tgc, search for it. or sometimes its printed on the bulb.
    09-10-2003
    Charlotte, NC
    4,463
    no they don't.
    do you get a diff. harness with the altezzas? or just a smaller bulb with the same size base? all news to me.. oh well. i'll never be getting those things
    you get a new harness with new bulbs. take the tails out the box and plug them in
    Calipso
    no they don't.
    yea they don't use the same bulbs. The altezzas are plug and play basically. Unfortunately my stock tails are cracked and I need to replace all the bulbs in my altezzas. Anyone?
    i don't have my tyc's anymore so i can't confirm but according to the search tool the reverse is 921 and the others are 2157 but take out the bulb and confirm just to make sure
    Calipso
    Thanks pinoy. My stock tails have a crack that seem to collect water in the tail light. As "eh" as my tyc's look, alot better than cracked ones.
    Calipso, I believe the following to be the TYC taillight part numbers(99-03 Galant);
    TYC81-5693-30 - Carbon Fiber
    TYC81-5693-40 - Black
    TYC81-5693-00 - Chrome
    what is the bulb for the turning signal in 2nd gen taillights
    I see the instrument bulbs are listed as 158, 168, 194.
    Will any of these work for the climate control. I've got one bulb out and it's driving me crazy...
    i can get you a bulb or two if you're interested. i have a pile of these just sitting here collecting dust. let me know if you're interested.
    04-10-2005
    NYC
    3,695
    does anyone know the size bulb in the ac/heat control
    as well as the mirror and foglight switch area i just need to change the 2 thanks
    the ac/heat control uses a 73 size bulb i believe
    and the fog light and mirror switches dont' have replaceable bulbs. the bulbs are soldered to the circuit board.
    what about the bulb underneath the a/t shifter
    <div class='quotetop'>QUOTE(G-spot)</div><div class='quotemain'>what about the bulb underneath the a/t shifter</div>
    194
    09-10-2003
    Charlotte, NC
    4,463
    its strange because it says the dome bulb DE3175 can be replaced w. a 561 but they make replacement DE3175 bulbs that dont have the rings on the end that we need to hook em in.. but on the 561s they are on there
Tags for this Thread
