Thread: 8G Galant bulb list
Showing results 41 to 60 of 66
  1. #41
    Quote Originally Posted by IceDouTGaLanT View Post
    ^ Their called City Lights Bulb "BA9S"
    Get some LEDS for them, it be much better!
    Thanks,
    That's exactly what i wanted, but now i think about it,
    do they feed off the low beams?
    I have HIDs will they be visible at all?
    - If you've got nothing nice to say, what the hell is wrong with you!?!
  2. #42
    you can tap them into your parking light lead, so when u have ur parking light on such as "auto starter" it will light your headlight housing very nicely. They are not going to very bright like your low beams no where close to that brightness.
    00 Galant ES Turbo/5-Speed
    13 GTR
  3. #43
    09-10-2003
    Charlotte, NC
    4,463
    reverse lights for 2nd gen JDM same as 3rd gen?
  4. #44
    is it bulb 561 for the front map/courtesy lights? it looks like them but i wanted to make sure before i ordered some leds for them.
  5. #45
    04-29-2009
    Holyoke,Massachusettes
    3,600
    I'll add 1891 for JDM city lights
    FreakyDeaky
    2kG 6g72/74 5 speed
  6. #46
    TGC Regular Redhaze's Avatar
    10-02-2010
    North Carolina
    774
    Whats the bulb size in the Vanity mirrors
  7. #47
    Quote Originally Posted by Redhaze View Post
    29mm
    http://store.ijdmtoy.com/F30-WHP-Fus...9mm_sku_2e.htm
    i put this in my car and look great :)
  8. #48
    02-08-2012
    Hackensack NJ
    1,146
    I did too but I got the one with 6 SMD LEDs on it
  9. #49
    02-08-2012
    Hackensack NJ
    1,146
    Also 7440 wedge bulbs aren't interchangeable with 194? Are they?
  10. #50
    02-08-2012
    Hackensack NJ
    1,146
    Quote Originally Posted by 00GalantMan View Post
    3rd Gen JDM tails
    taillight/brake light - 7443
    brake light - 7440
    reverse light - 7440
    turn signal - 7507
    Are you sure these are the bulbs? I just got mine and they're all 1156/1157 bulbs
  11. #51
    12-13-2010
    Brooklyn, Maryland
    4,643
    ^^They are the ones for the JDM bulb holders, perhaps yours are modified USDM bulb holders. I had to buy all those when I installed mine.
    -Greg
  12. #52
    hey, i got a JDM 8g galant 2003 (like in my signture)
    i was wondering what bulb type & size do i need for
    * digital climate control buttons
    * glove box lighting also
    i wanna switch them in led and i cant' find the bulbs types of Galant anywhere :S
    thanks alot
  13. #53
    TGC Regular P'NOYcaL's Avatar
    10-23-2009
    Bergenfield, NJ
    504
    Quote Originally Posted by galant350z View Post
    what about the new style vr4 dual fog lights? H3 right?
    hey guys! can someone confirm this? mines need some replacement..
    Bulb type for NEW style vr4 dual fog both inner/outer.
    Thanks!
    ________________________________________
    -RON
  14. #54
    2000 Galant climate control LEDs
    I'm in need of two replacement bulbs for a 2000 Galant GTZ Climate controls. These were stock.
    Here's a look at what I found and the number (8) and letters (K & J) are the only clues I have as to what they are. There were four total; they look like LEDs to me.
    Two black bases (J, yellow lamp) on the far left and right (??), a brown base (8, green lamp) and a grey base (K, blue lamp).
    The J-type shown is from the far left of the climate control panel, illuminating the hot/cold dial.
    8 and K are from the center and associated with lighting fan speed and illuminating the AC on/off.
    On the right, I believe was another J type but that one got lost so it needs replacement too. It was still attached to its base.
    Any help in identifying/sourcing replacements would be greatly appreciated.
    Thanks!
  15. #55
    TGC Regular bgood12's Avatar
    07-17-2009
    554
    Bulb 194 ledwholesalers.com best bulbs, work with dimmer switches, and bright
  16. #56
    I found a 1999 ES v6 wreck that I pulled the climate control LEDs from. They're a bit different than my 2000 GTZ; three are yellow. Here are the middle two:
    The bottom of the climate control unit is also different. In the 2000, the LEDs on the far left and far right are covered by the light plastic housing. In this 1999 ES v6, all four LEDs are easily accessible:
  17. #57
    Quote Originally Posted by P'NOYcaL View Post
    Thanks!
    anyone know the outer?
  18. #58
    The outers are P21W, I think similar to the 1156 but not certain.
  19. #59
    Thanks!
    I know this question is ancient, but if anyone is looking for the answer, yes the inners are H3. Inner H3 and outer P21W
  20. #60
    I believe I have 1156 in my outer ones.
    Sent from my Galaxy S4
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
Tags for this Thread
