Does ANYONE ever did this mod using the OEM switch..??? If so, Can you Explain how??
Thanks....
Nevermind... Just Found it
wow i never noticed in your sig that you had your fog's on.Originally Posted by devgrp
Thanks....
devgrp, did you ever finish the write up? I really want to do that mod and I'm located in Queens
I never did finish the write up, but its not that hard. Refer to the first page for instructions
ok.. so where do i get a "spdt" relay from ?
MARCH 2009 COTM
fully interfaced with Xbox Media Center. learn more at www.xbmc.org[/b]
Ballin' on a budget
<div class='quotetop'>QUOTE(GUTTAZMITZ)</div><div class='quotemain'>ok.. so where do i get a "spdt" relay from ?</div>
Any auto parts store.
ok i guess i'll take a shot at it too.. looks like everyone else is commin out sucessful.. I know if I can wire neons n everything else this shouldn't be as hard...
MARCH 2009 COTM
Ballin' on a budget
Did you have your grill inserts painted or did they come like that? :?Originally Posted by BKLYNLANG1
Is that red a stock color? If so what its color code?
Anyway yes the GTZ has colorkeyed grille.
yes the grill insert come painted stock on the gtz model...the color is patriot red pearl
Let's stay on topic you guys...This is a Tutorial.
-Pedro
<div class='quotetop'>QUOTE(Kalamidad)</div><div class='quotemain'>Let's stay on topic you guys...This is a Tutorial.</div>
We should put it in that section.
sorry about that
CAN WE MOVE THIS TO THE TUTORIAL SECTION, PLEASE.
-Pedro
Brought in from another thread...
<div class='quotetop'>QUOTE(lKoRTy)</div><div class='quotemain'>I want to do the fog light re-wire but i cant figure out which white wire to cut lol...
if relay is what i thougt it is.. then there r 4 wires coming to it? 2 red and 2 white? .... confused.. tell em where the relay is and what wire to cut lol.</div>
Being how devgrp stated that there are only three wires, you are definately looking at the wrong relay. Look at the diagram on the fuse box cover...there should be a half circle with three waivy lines next to it. That's the corresponding position for the fog light relay.
it is the one next to the large gray box, on the side closest to the battery and in the position closest to the front of the car.
-Pedro
ok i opened up the fsm and read through it.
let me start off with this picture
this picture shows the location of the relay in the 99-01 models but more importantly, it shows that the relay has 4 terminals. 1, 3, 4 and 5. notice the pin diagram on the relay. keep that in your head.
now here's the wiring diagram for the relay.
notice i circled the 1,3 4 and 5. it might look like there's 3 wires since 1 and 4 come from the same place. but yea, don't mess with that.
you'll be messing with the wire that is marked 3. this wire goes to the ecu. when you turn on the fog lights, the ecu grounds the wire marked 3.
but yea, back to the tutorial. take that wire marked 3 and cut it. now you have two wires. the wire that goes into the relay. thats the one you connect to a switch and ground.
- Chris -2006 Mitsubishi Eclipse GS 5MT: My DD
DRL Delete | 6K HIDS | AUX Cord Wired in RF Head Unit | DC Sprots CAI | OBX Longtube Header | Aero Turbine 2540i Muffler
you brought back a 3 year old thread
