<div class='quotetop'>QUOTE(VegasMatt)</div><div class='quotemain'>I will be running a S-AFC and was wondering if I should go ahead and get an A/F Gauge. Â*Would I need the gauge to tell if I am running lean/rich, or would the AFC tell me?
Thanks.
Matt</div>
If you're planning on leaving the AFC hooked up all the time, Matt that's all you'll need. If you're just going to use it for tuning, then unplug it, you can get an A/F meter, but keep in mind it will only be accurate at WOT.
Chip
