Thread: " System To RICH"
Showing results 1 to 15 of 15
    06-09-2004
    Maryland/RAF Lakenheath England.
    714
    " System To RICH"
    Ok , as usual the light "Check Engine Light" goes of.. System to rich , because of intake as usual.. , but my car smells funny when im putting the gas pedal down of course.. like it really is running really rich. IS this normal for a simple intake mod? stinks..
    Donovan J.
    Need something from england..or other eastern nations holla...
    I dont mind looking.
    Car: Toyota Soarer GT-T Jspec "Limited"
    Galant: at home chillaxen :(
    12-17-2002
    Sherman Oaks, California
    4,304
    did you reset the ECU after you put in the intake?
    http://socallifestyle.com/
    1994 Galant GS 5spd
    did you fix your o2 sensor yet?
    06-09-2004
    714
    02 fixed , when I did a scan on the computer it just said to rich..nothing about an o2.
    Donovan J.
    05-14-2003
    Southern California
    1,404
    No its not normal.
    Did you reset the ECU parameters (ie disconnecting the battery for a while)?
    Im wondering if that is a bad reading. I mean shouldn't the engine be able to accomidate a rich condition fairly easily (atleast in a mostly stock car ~ ie no FI).
    06-09-2004
    714
    Quote Originally Posted by peanotation
    yes I reset the ECU , then it just came back on..
    Donovan J.
    06-09-2004
    714
    Quote Originally Posted by Jet Black
    No its not normal.
    I dunno bro , this sounds like it might turn ugly if I dont figure out whats wrong.
    Donovan J.
    sounds like you blew another O2 sensor, what kind did you replace the last bad one with?? mitsubishi? did you have anybody install it?? dealer perhaps?? maybe if so they could look at it since they did it??? i would definately look into that.
    [20:33] fenderi: did they screw up your wiper leds yet?
    [20:33] lKoRTy: i dont know man
    [20:33] lKoRTy: i wil see topmorrow
    [20:33] lKoRTy: lol
    [20:33] fenderi: hopefully they did the car a favor and chucked them
    [20:34] lKoRTy: screw you
    12-17-2002
    4,304
    what brand is the o2 gauge? really shitty o2 gauges weaken the o2 signal, so the ECU might be getting a flawed reading and is deciding to just keep things uber rich to be safe about it. i've heard horror stories about those generic o2 gauge on ebay.
    1994 Galant GS 5spd
    GalantGuy96
    o2 gauge?.....you mean sensor right..?
    12-17-2002
    4,304
    Quote Originally Posted by GalantGuy96
    no, since the o2 gauges intercept the signal, the shitty cheapo ones weaken it considerably. too much impedence, so the ECU is getting a haggard signal. when i my s-afc2 hooked up to the o2 sensor, along with my seperate o2 gauge, my o2 reading was skewed by about 0.3volts
    1994 Galant GS 5spd
    does the stink smell like eggs? if it does you need to get your cats checked ASAP. you could ruin them w/ too much fuel (from running rich too long or too much) going through them and burining the ceramic and catalyst.
    where did u get o2 gauge from?? he said he found out it was running rich my running a scan tool.
    RadRICH - TGC Founder BGR's Avatar
    12-09-1999
    FLORIN - Sacramento, CA
    1,996
    I've had similar problems. I'm driving along and then the check engine light comes on and my car starts to sputter. I'm finally able to get home but black smoke is pouring out the tailpipe. I disconnect the battery and check the MAS and Intake. Everything looks okay. I reconnect the battery a few hours later and the problem still exists. I then leave it off for a day and it seems to be okay but later that day the problem came back. It was so bad that I burned a 1/2 tank of gas in only 12 miles. I kid you not. So I disconnectedthe battery again for a few hours but that didn't help. I then left it disconnected for a few days and that did the trick. I never replaced the O2 sensor no replace the fuel filter. I probably should but I haven't had any problems since. That was about a year and a half ago. Knock on wood.
    06-09-2004
    714
    peano: I bought the 02 sensor used from a vehicle iwth 29k miles on it
    Reelax: it does smell like eggs
    BGR: perhaps I should try that , I wanna see what reelax was talking about first about the cats..
    I may have to do what BGR did and leave it disconnected for about 2 3 days..
    Donovan J.
