Thread: manual trans fluid check
Showing results 1 to 4 of 4
    ramell86
    Can anyone help me find the fluid check plug for a 89 manual galant?
    The manual doesn't give a very good description.
    Thanks
    ken inn
    should be about half way up the front of the trans(it will be facing the radiator). on my car, it has a 19mm head. here's a hint. do NOT drain your trans until you can break this filler plug loose.
    ramell86
    Yeah thats where I thought it was, just wanted to check.
    I am having a heck of a time trying to break it, and i figured i better get that off before I drained the oil. Thanks for the help.
    ken inn
    another hint, use a 6 pt socket. i try to only use 6 pt sockets. if you round this off, you will have to drop the trans to get it off. there is no clearance in there.
