Thread: Custom Headlights...
Page 1 of 6 12345 ... LastLast
Showing results 1 to 20 of 112
    Im pretty sure alot of owners have thought of this.. how about customizing a Low Beam and High Beam for our 7th Gen? like similar to these head lights...
    http://www.mulsanne.com/html/morette.html
    For example, making a headlight bezel and putting a Projector Low/Hi Beam
    http://db.hella.com.au/cgi-bin/catalogue.p...ew&flmaint=2461
    and Hi Beam
    http://db.hella.com.au/cgi-bin/catalogue.p...ew&flmaint=2462
    Feel free to reply...
    8G_GTZ
    been done by a few members.
    Steve
    09-23-2002
    Port St. Lucie, FL
    666
    I've never seen a 7g w/ headlights like that before... where have you seen these headlights???
    I was thinking of fabing something up like that... looks like a cool ass project
    when is we gon be free????
    Quote Originally Posted by shogun7g
    Steve
    Really? I havent seen any. I know Z started one as a project but that was the last i heard of that.
    I was actually thinking about that last night though :shock:
    Signature wanted call: 1800-Darkkend
    <a>Take Better Photoshots Tips from the Pro's</a>
    09-23-2002
    Port St. Lucie, FL
    666
    The closest one to a 7g is the old school impreza... If you could fabricate something that could replace the headlight lense(clear plastic) this would be no problem
    12-17-2002
    Sherman Oaks, California
    4,304
    never been done on a 7G before, to my knowledge. we have horrible light output from our housings, so anything is better than stock.
    http://socallifestyle.com/
    1994 Galant GS 5spd
    if someone can make it.. what kind of material should be used for the base of the lamps? fiberglass or abs plastic? all we need is to make a mould and a base to hold the lamp stable?
    Kansas City, MO
    1,244
    never been done probably cause most 7ger's won't pay $500+ for some headlights, hell that's half a turbo install.
    09-23-2002
    Port St. Lucie, FL
    666
    the housing wouldn't be too hard too make... how much do the hi and low beam assembly cost?
    Experienced TGC Member njjfudge's Avatar
    02-28-2005
    Jonesboro, GA
    1,447
    I saw this 94 7g on cardomain but they changed the whole front end
    http://www.cardomain.com/memberpage/468913
    <div class='quotetop'>QUOTE(njjfudge)</div><div class='quotemain'>I saw this 94 7g on cardomain but they changed the whole front end
    http://www.cardomain.com/memberpage/468913</div>
    Looks like they fiberglassed over the stock headlights, and that california top looks pretty good on the 7g, wonder how it looks with the top open and fully retracted.
    hi.. just updating this thread...
    On monday im going to shops/companies that customizes plastic moulds. How many 7G owners would really be interested in this if i can get the shop to fabricate moulds of our headlamp assemby to hold a projector type(low beam) and sealed type (hi beam)
    Has anyone photoshop'ed a 7G with clear headlamps and projectors?
    if you can guys can do something like this for a 7g i will be first in line, the only problem is there are enough impala and caprice guys for that guy to make those, I dont know if theres enough of 7gers here to do custom headlights like those. But that guy started with hella projectors and the little blue one is a driving light (optional on the kit he's making). and the one on top of the little blue one is the turn signal (which is inboard on the caprice and impalas of the 90's)
    well i've contacted a couple of companies they said the minimum they would fabricate is at least 20 for a headlamp assembly.. so i just need to make sure that at least 20 people are definitely in... still unsure of how much money im about to throw away at this project...
    Proto
    you can put me down
    if they look good im down for this, if you want i'll photo shop those caprice/impala lights into the 7g.
    Im in if the look good lets see the photoshop version.
    12-17-2002
    4,304
    pending some pics, i'm in too
    1994 Galant GS 5spd
    cool.. is it possible to try using the hella ones i've posted earlier.. cause that'll be the one ill be using..
    i believe moulding the mounts for the projector and sealed beam is easy.. but getting a clear cover for the fronts, i think it'll be hard.. i know i wouldn't want them to break/chip when struck by stone chips or pebbles
    02-28-2005
    Jonesboro, GA
    1,447
    Someone on cardomain put some BMW 748il headlights in the 7g housing.
    LOOK!!!!!!
    Never seen anyone else do that. 8)
