fuel pump
where is the re-wiring diagram for the fuel pump?
Vfaq. <that's not a link, cuz I don't know the address for the vfaq
I have seen posts addressing the vfaq, but when I go to the faq area, I don't see anything about fuel pumps. (what does the v in vfaq stand for?)
Member
www.vfaq.com
scroll down and there's a link to the tutorials.
Look under fuel or something, then there's many different re-wiring. It's self explanator.
Run 10g from battery to a relay. Use the factory power wire that went to the fuel pump, to turn the relay on, then you have the 10g which gives the pump the power. Use another 10g for grounding the relay.
have you done this yet jesse? we may have to do this on satuday sometime
Thanks!!
I was looking all over TGC for it.
The first tutorial for the DSM AWD, that is what the Galant has?
Sounds pretty easy, I'll have to give it a try.
Member
This is applicable to all fuel pumps.
No seth, I haven't done it yet, would you like to come early and we'll do both our cars together?
Later
So what do we use the 2g fwd instructions?
<div class='quotetop'>QUOTE(BEAST)</div><div class='quotemain'>So what do we use the 2g fwd instructions?</div>
Yup. Just remember, it's not going to be 100% accurate, since it's being done on a FWD turbo Eclipse, but the basics and wiring are the same. But don't be surprised if they mention something that you don't have or you find something in the way that wasn't in the Eclipse.
well me and jesse re-wired my fuel pump last weekend. i think i did notice a little more difference, but nothing *big*. If you are NA it will not help you nearly as much as if you were runnin turbo. One of Jesses' friends owns a Talon TSI and he said he did notice somewhat of a big difference when he rewired his...so yep
ill get some pictures of everything sometime.
