disconnect your battery, so it doesn't drain. Fill up your gass tank, and put a bottle of fuel system cleaner in it.
When you get back, do an oil change.
After you finishe the oil change, check the tire pressure by doing a burn out and you should be fine.
but seriously, do check the tire pressure.
