Thread: 7g turbo install complete and running
Page 3 of 3 FirstFirst 123
Showing results 41 to 59 of 59
  1. #41
    Quote Originally Posted by sabzi5858
    good work peano, glad you aren't a ricer anymore
    sorry dohcstunr, i was using those copper bends back when i had a 1g bov. i'm using them again now on the hks ssqv temporarily while i work out some tuning issues. the only reason i used them before though is because it was the first thing that popped into mind. now i'm using them because it's the only way i can route it without the hose pinching.
    a recirculated bov shouldn't be loud, it shouldn't be audible from another car.
    damn you beat me again sabzi :?
    yeah thats pretty much why i had to use them, cause the hose i had would go flat, and home depot is a block away. but i have a injen style aluminum intake, you can hear it. its not nearly as loud as venting, but you can hear it from the sidewalk( i just put a filter and adapter on my friends all stock gst and you could hear his crappy 2nd gen bov hit, real quick and high pitched) i think it has something to do with the metal reflecting sound back through the filter. but then again, my hks racing bipass valve doesn't have much of a ricer sound to it. sounds more like a semi truck bov, cept without the tremendous psi.
    when i get my upper intercooler piping welded into one piece instead of 3, i'm going to reorientate my flange. so i shouldn't need any bends to recirculate.
    sabzi, did you drop the maft setup?
    if its for sale i got first dibs please sir.
  2. #42
    Bronx NYC (reppin)
    3,489
    [quote="peanotation"][quote the next mods would be a true tuning system, not my ghetto setup with only afc2, boost, egt and a/f gauges. also, need a new oil pan.
    quote]
    I have a fresh oilpan in the garage with your name on it dude. anything you need i got it.
    Again very nice job man.
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
  3. #43
    12-17-2002
    Sherman Oaks, California
    4,304
    i got a turbochargers.com style oil return line. i put the 1g one on and it just had bad news written all over it. i leak oil from where it bolts up to the drain pan, only because one of the nuts is stripped, so it's kind of being held in by one fully strong bolt and one half-strong bolt. that make sense? i just got to get a new gst drain pan.
    the bov was really loud when i didn't have the recirculation tube, but immediately after the blow off the engine would just start choking. so after i hooked up the recirc tube its really loud if i shift in the middle of my peak boost.
    http://socallifestyle.com/
    1994 Galant GS 5spd
  4. #44
    Proto
    looks good peano 8)
  5. #45
    if its for sale i got first dibs please sir.[/quote]
    i'm still using the maf-t, but it actually has to be tuned in to mimic the stock mas. it isn't a plug and play solution like initially thought, it can run rich or lean, seems to vary person to person, so it needs to be tuned in on an individual basis. so now i have to get a good tune with the stock mas, the tune the maf-t to mimic it. sucks. someone local is starting to sell something called a pro-m, it is similar to the maf-t, but supposedly better. i will let you know details once i find out. personally, i want to move over to a standalone and get rid of the maf-t, but it will have to wait a bit.
    sorry if i asked you this before, but are you running the hks racing type II bov? if so, do you get any surging (aka flutter) from it? my hks ssqv is surging all over the place, and it looks to be in perfect condition, although i do have leaking fuel injector seals. but once those come in, if it doesn't fix the problem, i may have to look into getting a new bov. :?
  6. #46
    Congratulations man, I know you wanted this for awhile. Hope everything keeps going according to plan.
  7. #47
    07-20-2003
    Orlando, FL
    3,169
    Very nice Peano...definitely the most different recirclation tube I have ever seen....but if it works thats what counts. When does you boost hit in the RPM's...I am assuming sooner than the 14b's. Also...I have to ask if its just me....What are you using for your lower radiator hose? That thing looks like vaccume cleaner hose stretched pretty good. 8)
  8. #48
    12-17-2002
    4,304
    Quote Originally Posted by 4-G-rim
    at 2.5K rpm it hits 0psi, hits full boost at round 3.5Krpm. falls off after 5K to about 4-6psi. that hose is actually a flexible radiator hose from pep boys, works really good. had to replace the OEM one because it was directly in the way of the intake pipe.
    1994 Galant GS 5spd
  9. #49
    wow, i would expect it to spool a lot earlier than that. my 54 lb/min turbo spools around 3800-4000rpm on a 2.0l.
    perhaps you should try a manual boost controller to keep the wastegate from opening until you get closer to full boost.
  10. #50
    You can make a JoeP MBC for $12 worth of Home Depot parts.
  11. #51
    12-17-2002
    4,304
    1994 Galant GS 5spd
  12. #52
    looks great Matt, your going to make a tutorial? your one of the reasons why I want to modify my g. Keep up the good work!!
  13. #53
    12-17-2002
    4,304
    Quote Originally Posted by 95mitsu03
    i thought about it, but brandon's is really good. short, simple, no bullshit, cuts right to the point. plus, i wrote the tranny swap tutorial and no one reads it. people still asking for tranny swap tutorials.
    1994 Galant GS 5spd
  14. #54
    Quote Originally Posted by peanotation
    dont worry I am using your tutorial for the 5spd swap . brandons write up is good but all its missing is pics :? , but I'll use it as a guide. what I like about your tutorial is the step by step with pics so its very helpful. 8)
  15. #55
    12-17-2002
    4,304
    thanks. for the turbo i read the Spyder 4g64 turbo page as a basic guide, and brandon's basic tutorial just cleaned up a bunch of questions i had. between looking at pictures of djplay's car, talking to dohcstunr for hours, and peeking around on dsmtuners, i pretty much knew everything i needed to know. only problems i ran into were parts not fitting or working right.
    1994 Galant GS 5spd
  16. #56
    vids?????
  17. #57
    Mindless
    vids?????
  18. #58
    at least give us some sound clips you cock tease!
    VIDS NOW!!
  19. #59
    what am i saying, i haven't even made real video yet.
