Last I heard the emanage does not controll boost, tack on an extra 300.00. Gauges, Wide band, etc extra 500.00 Your already at 3300 not including the trans your going to need from the 3gen eclipse or did you think your I4auto would support that power? Your well above 4k before the cost of install and tune comes into play. Your trying to cut financial corner while doing a sever swap WHY? get the latest version of the SDS + 5sp swap call it aday. It comes with pretty much everything you need to worry about...
Hell if you want to do something outstanding figure out away to make the auto trans survive that much power.
You are right about one thing...peicing together a turbo setup would be a pain
