Thread: How to fix the gap in the glove box
Showing results 1 to 5 of 5
    I got this bulletin from the 9G service manual; thought I would just share the info.
    Some affected vehicles may have a gap at the upper left corner of the glove box and the dash.
    To realign the glove box to eliminate the gap, follow the procedures in this bulletin.
    AFFECTED VEHICLES
    2004-2005 Galant
    PROCEDURE
    If there is a gap between the dash and glove box in the upper left corner, adjust it as follows:
    1.Open the glove box.
    2.Loosen the four glove box attaching screws (two on the right , two on the left)
    3.Push the glove box striker and the instrument panel garnish at the center of the glove box forward. While pushing forward, tighten the four attaching screws.
    4.Close the glove box and verify that the gap is eliminated.
    Another bulletin listed another procedure for the gap:
    PROCEDURE
    If a vehicle has a gap between the dash and glove box in the upper left corner, adjust the glove box as follows:
    1.Remove the glove box tensioner (small nylon cord).
    2.Remove the glove box and garnish.
    3.Remove the dash bolt in the lower right corner of the dash.
    4.Install a 2 mm washer (listed in the PARTS INFORMATION section of this bulletin) behind the bolt, then reinstall the bolt.
    a.Reinstall the glove box and verify the gap is eliminated. If a gap is still
    observed, install another washer behind the bolt.
    b.If more additional washers are required, and the bolt is too short to accommodate them, replace the bolt with the longer bolt listed in the PARTS INFORMATION section of this bulletin.
    2004 Galant LS
    Yet they didn't have a cure for the 8g glovebox rattle...pricks!
    <img>
    errika
    thanks!! i had that gap!
    Feared
    awsome, thanks for the find! i was wondering if it was just mine that was doing that..
