Thread: 5-spd conversion question
Showing results 1 to 2 of 2
    94gntturbo219
    Well, I found out because I asked for either a galant or eclipse shifter and pedals. I meant galant pedals and eclipse shifter, cause I know both of those are the same, but are the pedals and mounting points the same for a 5-SPD between the 7G galant and the 95-99 eclipse?
    Also, Are the shifter cables the same or no?
    yea its all the same.
