Thread: Donor G for my 5 speed swap, what can i use from her???
Page 4 of 4 FirstFirst 1234
Showing results 61 to 70 of 70
  1. #61
    guys what brake lines should i use???
    I heard the Stainless Steel brake lines from the 2g eclipse is that correct??
    1994 GS DOHC 2.4L 5spd (For Sale)
    1996 S SOHC 2.4L 5spd (Up and Running)
  2. #62
    Can use 2g lines, they hvae kits on eBay for like $60. Upgrade the shifter base bushing man! Grab the energy kit for the 2g off eBay for $10. Takes 5 minutes to install, the old bushings are so SOFT!
  3. #63
    Quote Originally Posted by Joaltava
    i ordered a kit for a 2g spyder for my GS
    had the exact some fittings and lengths.
    it was a magnum kit from ebay. like 60 bucks. nice clear pcv coated stainless lines w/ steel fittings that won't strip out like aluminum.
    one of the best upgrades i ever did.
    and the shifter plate bushings are like chewing gum. i've said it a thousand times: replacing those with a steel or energy kit will bring you car to life. no more missed shifts, nice crisp shifter feel.
  4. #64
    Old on the left, new on the right.
    Another must is the B&M replica short shifter!
    And lastly do the skateboard bearing mod for the shifter cables under the hood and you will have a crisp smooth shifting Galant for under $75!
  5. #65
    OK thanks guys.
    this is what i found so far on ebay
    http://cgi.ebay.com/ebaymotors/Stainless-S...sspagenameZWDVW
    Also DOHCSTUNR where did u buy urs cause i cant seem to find for the eclipse spyder on ebay.
    Also seth i found a B&M short shifter and they go for more than $100 dollars. Now i found some copys that go for alot less here's what i found
    http://search.ebay.com/search/search.dll?s...prclo=&saprchi=
  6. #66
  7. #67
    Yes get the B&M Replica. Exactly the same design for 3/4 of the cost. Make sure you get the B&M replica and NOT the OBX with the ball on the bottum. Get this style:
    http://cgi.ebay.com/ebaymotors/95-99-MITSU...023938998QQrdZ1
    And those under hood bearings are nothing more then rollerblad/skateboard bearings. So if you dont have any rollerblades or skateboards sitting around then get those.
    And those shifter base bushings are the ones I have, just not the correct picture in hte auciton.
  8. #68
    thanks for the info man, ill get the short shifter and then the brushing for my car.
    Ill get the SS line later
  9. #69
    Yah I keep forgetting to get the SS line, only need the front for now though. Stupid rear drum brakes haha.
  10. #70
    Seth do you know anyone that sells slotted rotors for our G's for all 4 wheels??? Something like this picture??
    or
