Thread: Converting high bean and low beam
Showing results 1 to 4 of 4
    Blackattack98
    Did anybody convert the low beam into the high beam location? Let me know
    Dark Anghell
    Not that I nkwo of, but it's pretty easy to do though.
    hmmm would this be better?
    i dont think it would be that hard
    San Antonio, Tex-Mex
    1,413
    Uhhh, what purpose would that serve???
    The low beams are the outer ones fo a reason I'm thinkin'. Most cars headlights are designed that way, low beams next to the corner lamps. I'm sure there's a reason..
    <-Check it out Maz
    My 7g
