Thread: INDIGLO GAUGES
Showing results 1 to 4 of 4
    galant4u
    INDIGLO GAUGES
    With winter coming should I remove my reverse indiglo gauges?
    THANKS
    galant4u
    I dont Know if you need to. Thats why i posted this
    You do not need to remove your guages. The only thing I think you should think about removing for winter would maybe change your CAI if you have one to the short ram if possible and change your rims.
    Jason
    www.edelhausrottweilers.com
    stephen7983
    Definately remove those Indiglo Gauges. Because of winter, the atmospheric pressure along with the very low temperatures can cause your indiglo gauges to malfunction. No im only kidding you dont need to take those off for winter; they're inside your car, so don't worry. LoL
