Thread: Safc 2 install q's/help *answered/pics/dyno*
Showing results 41 to 60 of 81
  1. #41
    <div class='quotetop'>QUOTE(seth98esT)</div><div class='quotemain'>Dunno, I thought the 2g ECU rev limit was 7500, but I didnt feel the limitter. Â*Although I was spinning tires through first without a working tach haha!</div>
    Are you running a fully stock 4g63t?
    www.edelhausrottweilers.com
  2. #42
    Stock internals, cosmetic 4layer headgasket, and arp headstuds.
    So come on Krispy, give us some numbers, I know you got on the dyno
  3. #43
    08-23-2004
    Chaska, Minnesota
    1,370
    i was kind of upset about not even breaking 100. so upset i didnt even go to a local meet that i spent all day prepairing for
    i guess a good reason is that the afc isnt fully "installed" i need to find a stronger point to tap into the RPM wire.
    anywhoo my performance mods are as follows:
    AEM CAI
    superman decal
    DC header w/ custom exaust
    walbro 190 fuel pump
    S-AFC II
    magnacore plugs + wires
    someone please tell me this isnt bad.
  4. #44
    Hmm its not bad considering your Auto, I would have expected a bit more. You have a graph of the AFR?
  5. #45
    12-17-2002
    Sherman Oaks, California
    4,304
    pretty much stock 8G I4? looks good to me. thats actually about where you should be i believe
    http://socallifestyle.com/
    1994 Galant GS 5spd
  6. #46
    I would have figured you would have broke a 100 too.
    Might be the Superman Decal. Might need a bigger one....
    Or hook that fan back up......
  7. #47
    By the way Krispy... remove your VIN number from that picture if that is you VIN.
  8. #48
    08-23-2004
    Chaska, Minnesota
    1,370
  9. #49
    08-23-2004
    Chaska, Minnesota
    1,370
    BTW: thats wheel horse power not base horsepower!
  10. #50
    05-14-2003
    Southern California
    1,404
    lol you got to love torque multiplication. 350 ft-lbs @ 50 rpm.
    But seriously though, thats not all that bad. At the very least it should make Matt happy about his 188whp.
  11. #51
    12-17-2002
    4,304
    is that an awd dyno???
    1994 Galant GS 5spd
  12. #52
    08-23-2004
    Chaska, Minnesota
    1,370
    <div class='quotetop'>QUOTE(Jet Black)</div><div class='quotemain'> At the very least it should make Matt happy about his 188whp.</div>
    what the.. i thought he had 182whp
    <div class='quotetop'>QUOTE(peanotation)</div><div class='quotemain'>is that an awd dyno???</div>
    yes, fwd, rwd, and awd dyno. $75 dyno and tune
  13. #53
    12-17-2002
    4,304
    hey seth....
    13G OwNaGE!!!
    and at 47% throttle too
    1994 Galant GS 5spd
  14. #54
    haha mine was at 12psi with an exhaust leak. Wait till I turn up the boost! John hit 1800 today I think, he beat us both
    And I dont know how accurate the karman reading is. Post your air flow in ft/lb from your logger, o wait...... :lauging:
    But I still beat you by 20hz haha!
  15. #55
    Man... I will post my numbers when I get them. I have a fed spec so I hope my #s will be a little higher. I thought Galants had 141hp at the crank. say you loose 20% with an auto tranny, minus 28HP, that still should be 113HP stock without mods.
    '99 ES Fed Spec
    Apexi SAFC
    OBX "R" header
    2.5" header back exhaust
    Dynomax Resonator (replaced cat)
    Bullet style 4" muffler with removable baffle
    Injen CIA
    Denso Iridium Spark Plugs
    NGK wires
    AEM Underdrive Pulleys (Alt, Water Pump)
    16" Alba rims
    Interior:
    Leather seats (Aftermarket)
    Pioneer Head Unit
    Pioneer speakers
  16. #56
    here's my latest and greatest
  17. #57
    12-17-2002
    4,304
    my god, 1808hz :shock: :shock: :shock: :shock: wish i could hit 6,700 too 8) :shock:
    you realize there's a war going for maximum airflow now. i guess you hold the championship belt
    <div class='quotetop'>QUOTE(SpaceGhost711)</div><div class='quotemain'> say you loose 20% with an auto tranny, minus 28HP, that still should be 113HP stock without mods.</div>
    cars are never exactly precise. krispy actually dynoed right where he should have (in my opinion). you will be a lot lower if you don't fix those problems first though.
    1994 Galant GS 5spd
  18. #58
    <div class='quotetop'>QUOTE(peanotation)</div><div class='quotemain'>my god, 1808hz :shock: Â*:shock: Â*:shock: Â*:shock: Â*wish i could hit 6,700 too Â*8) :shock:
    cars are never exactly precise. krispy actually dynoed right where he should have (in my opinion). you will be a lot lower if you don't fix those problems first though.</div>
    He wasn't even at WOT....
  19. #59
    well i had to put on my old turbine housing cause a bolt broke off in my new bullseye housing.(had to take it to a machine shop cause the easy out broke off in it too :shock: )i'm also am running a 1g unported manifold temporarily till my new one gets here
    was running about 17 or 18 psi during that run.
    i think the airflow on the safc2 is going to be the accurate one cause the logger will show the corrected airflow from your safc2 output that the ecu sees. but idk.
    i hope to squeeze more airflow out when i get my housing bolted back up, and with my ported sbr manifold. should have much more top end flow.
  20. #60
    ok I am going to the mech and check my compression, exhaust leaks, and other thing included in a tune-up. Before I go, I am going to drive 'till my SES light comes back on.
    '99 ES Fed Spec
    Apexi SAFC
    OBX "R" header
    Injen CIA
    NGK wires
    16" Alba rims
    Interior:
    Pioneer Head Unit
    Pioneer speakers
