Thread: Safc 2 install q's/help *answered/pics/dyno*
Page 4 of 5 FirstFirst 12345 LastLast
Showing results 61 to 80 of 81
  1. #61
    08-23-2004
    Chaska, Minnesota
    1,370
    as for gas millage, my car, (8gen, i4, 13 gal tank) i got about 230 miles per tank. with the afc (not even properly installed) about 260 per tank.
  2. #62
    theblackpearl
    i want one...
  3. #63
    08-23-2004
    Chaska, Minnesota
    1,370
    lmao, it does make those cali meets seem not so bad after all.
  4. #64
    Your getting pretty bad gas mileage. If I boost around town I get at least 250mpt, if its all highway miles I get 300-400mpt.
  5. #65
    screw u all 210 MPG in city if im lucky!! 8g v6 :evil:
    Diego
  6. #66
    08-23-2004
    Chaska, Minnesota
    1,370
    im pretty sure you have a better fuel management than i do. im going to have to fire mine and hire a new one.
  7. #67
    i want one now
    www.anti-rice.com
    lasthopeskrispy: so i was fucking this guy in the ass over the weekend and you know what he decides to do....he reaches around and cups my balls. I was like hey what a fag!
  8. #68
    i want one now
    www.anti-rice.com
  9. #69
    12-17-2002
    Sherman Oaks, California
    4,304
    <div class='quotetop'>QUOTE(krispy03)</div><div class='quotemain'><div class='quotetop'>QUOTE(seth98esT)</div><div class='quotemain'>Your getting pretty bad gas mileage. Â*If I boost around town I get at least 250mpt, if its all highway miles I get 300-400mpt.</div>
    im pretty sure you have a better fuel management than i do. im going to have to fire mine and hire a new one.</div>
    i was gonna say, i get about 230-250 miles on a tank, and my turbo spools more often than chicks turning me down for a date
    OWN3D!
    http://socallifestyle.com/
    1994 Galant GS 5spd
  10. #70
    Tonight, after fixing a intake leak where the cap for a nipple on my intake came off. unmetered air was coming in after my MAS and throwing off my ratio.
  11. #71
    I am trying to install mine with not much luck. I have power to it. I am using cluster of ground wires right below the harness. I connect the RPM signal wire from the SAFC to pin 45, (cam sensor) and am not getting a reading. I do not want to go any further until I get this figured out. Does it really matter what I ground it to? In the book it says the brown wire must be closer to the PCM than the black wire. How important is that? thanks
    '99 ES Fed Spec
    Apexi SAFC
    OBX "R" header
    2.5" header back exhaust
    Dynomax Resonator (replaced cat)
    Bullet style 4" muffler with removable baffle
    Injen CIA
    Denso Iridium Spark Plugs
    NGK wires
    AEM Underdrive Pulleys (Alt, Water Pump)
    16" Alba rims
    Interior:
    Leather seats (Aftermarket)
    Pioneer Head Unit
    Pioneer speakers
  12. #72
    I answered my own question. Hope this helps other ppl.
    http://club3gfl.com/board/showthread.php?p...=29626#poststop
    '99 ES Fed Spec
    Apexi SAFC
    OBX "R" header
    Injen CIA
    NGK wires
    16" Alba rims
    Interior:
    Pioneer Head Unit
    Pioneer speakers
  13. #73
    08-23-2004
    Chaska, Minnesota
    1,370
    Quote Originally Posted by DOHCSTUNR
    god damn! i hit that once
    than i woke up in a cold sweat of my own uren.
  14. #74
    12-17-2002
    4,304
    more 13g wrath:
    1994 Galant GS 5spd
  15. #75
    mmmmmmm nice.
    getting cold up there?
  16. #76
    01-24-2005
    DFW/Stillwater
    2,752
    i thougth the i4 had 140hp at the crank? this goes all the way down to 90's when at the wheel? so how much does a stock galant hav at the wheel? like 89hp?
  17. #77
    08-23-2004
    Chaska, Minnesota
    1,370
    probably
  18. #78
    fantasykills
    4 galant 2000? ecu wiring diagram safc?
    FYI for future reference on installing A'PEXi S-AFC II, bottom of page 500 in the link above,
    11 is your rpm wire, 41 is your power wire, 42 ground wire, 65 is your air flow signal wire, and 78 is your throttle signal wire. we have no knocking signal.
    In the A'PEXi S-AFC II wiring diagram book refer to page 48, terminal drawing M6-b
  19. #79
    09-10-2003
    Charlotte, NC
    4,463
    Re: 4 galant 2000? ecu wiring diagram safc?
    <div class='quotetop'>QUOTE(fantasykills)</div><div class='quotemain'>FYI for future reference on installing A'PEXi S-AFC II, bottom of page 500 in the link above, Â*
    11 is your rpm wire, 41 is your power wire, 42 ground wire, 65 is your air flow signal wire, and 78 is your throttle signal wire. we have no knocking signal. Â*
    In the A'PEXi S-AFC II wiring diagram book refer to page 48, terminal drawing M6-b</div>
    Sticky this?
  20. #80
    08-23-2004
    Chaska, Minnesota
    1,370
    ^^^ i said that over on page 2
