Thread: 9G Galant/4G Eclipse Turbo Kit
Showing results 1 to 20 of 24
    11-05-2003
    San Francisco Bay Area
    1,517
    Thought you 9G guys would be interested in this:
    http://club3gfl.com/board/showthread.php?t=4758
    awsome find!
    it has begun! he he he... :twisted:
    theblackpearl
    oh wow...this is gonna be good if someone gets that..which they definitly should!
    07-20-2003
    Orlando, FL
    3,169
    The gains from the dyno sheet don't look impressive. Maybe they were conservative since probably those motors have pretty high compression I assume...8:5:1 pistons and turn up the boost I say!
    honestly i think a 100 peak whp gain is pretty sweet.
    not bad torque numbers either.
    i think torque could be improved as well.
    i can't believe they run that thing so lean. yikes.
    looks like it needs a fuel system upgrade for sure if they want to make more power
    appears to pull all the way to 6100, a 3.8l v6 can really move some air. gotta have an effieciant turbo to keep up with that.
    i'm impressed. they did that dyno run only 4 weeks into the project
    i'm sure there is plenty of time to sqeeze more juice out of it. I mean, this IS a brand new engine for the mitsu tuner community to play with. i owuldn't expect enormous gains during the preliminaries.
    at least not until they've found out what this motor is capable of.
    here is the stock 4th gen eclipse dyno
    http://www.titanbending.com/eclipse/day1/dyno4.JPG
    Re: 9G Galant/4G Eclipse Turbo Kit
    Quote Originally Posted by wanderingpinoy
    Great news,wanderingpinoy! Leave it to the Eclipse, the most aftermarket, modified import car in history, to bring true performance for our 04-05 Galant's. Truely the best Galant ever made, the VR4 aside. . Some of us have been impatient for true performance parts, but a few years wait ain't that bad. If it wasn't for the new gen Eclipse, we wouldn't be seeing this at all. So thank you 06 Eclipse, I'm shedding a tear of happiness.
    Thats a horrible tune! He is running 14+ for half the run! He either needs bigger injectors or they need to learn how to tune. Unless these engines are GDI which they arent, Im surprised he didnt see any detonation.
    Tune?
    They will need to do a seperate tune for the Galant, due to the absence of MIVEC and the 30+ H.P. difference from the Eclipse! I don't know what the average dyno #s for the 3.8 liter Galant are. Anyone get theirs dynoed yet? I always assumed the H.P. from Mitsu was understated. I can tell you My GTS feels faster than my former 03 V6 Accord, considering it's heavier weight. Although, that may be due to the total absence of torque in the Accord, or any Honda for that matter. In any case, it's sure nice to know that turbo's and REAL performance parts are on the way for the 9th gens. At my age, I don't know if I'll be getting into any of it. In stock form the car is already much more fun to drive from a performance standpoint, compared to my Accord and some of the other cars I owned, "Heck" even a very mild F.I. would make this car a blast to drive, while taking care of it's weight disadvantage!
    i was going to say... it might be more impressive if these cars didn't weigh so damn much... but still pretty cool
    <div class='quotetop'>QUOTE(thebirdman13)</div><div class='quotemain'>i was going to say... it might be more impressive if these cars didn't weigh so damn much... but still pretty cool</div>I know the weight is a issue but, it's also front drive. The extra weight from the cast iron block pushes down over the front wheels to help keep the tires planted. The front of the car is raised more then the back, which helps with traction as well. I know it doesn't look as good as a lowered car with minimal gap, but it's purpose is effective.
    Anyone know the website or phone number to this company? I'd like to ask them some questions.
    Dragongts: I saw your input on Ripps forum. I called them a few times to express my strong interest on something for my GTS, unfortunately they never called back! The more interest they get, the faster they will start producing. It wouldn't be a bad idea to talk with ripp and see if we can get a group buy on a staged kit for the 3.8 liter V6. Theres gotta be at least 10 of us that want one!
    I know man! I've called approx. 5 or 6 times and have yet to hear back from them. I did however receive an email from them stating that they will begin working on the 6G75 engine in order to produce a kit. The Only thing, is that with the abscence of MIVEC, we will def. need a diff. tune. But you are right, if we keep calling, and in a way harrasing them, we should get some kind of response. :thumbsup:
    right now though, I am really interested in swapping my heads with the eclipses mivec heads. I keep telling my buddy, who works for Mitsu, to see what other parts I would need i.e. pcm, ecu, etc. in order to get the conversion done. but we'll see what happens. will most def. keep everyone posted. :ironchief2:
    05-31-2005
    4,735
    <div class='quotetop'>QUOTE(dragongts787)</div><div class='quotemain'>I know man! I've called approx. 5 or 6 times and have yet to hear back from them. I did however receive an email from them stating that they will begin working on the 6G75 engine in order to produce a kit. The Only thing, is that with the abscence of MIVEC, we will def. need a diff. tune. But you are right, if we keep calling, and in a way harrasing them, we should get some kind of response. Â*:thumbsup: Â*
    right now though, I am really interested in swapping my heads with the eclipses mivec heads. I keep telling my buddy, who works for Mitsu, to see what other parts I would need i.e. pcm, ecu, etc. in order to get the conversion done. but we'll see what happens. Â*will most def. keep everyone posted. :ironchief2:</div>
    Hint hint... Search for 2006 eclipse on Ebay!!! I was thinking of a conversion with my i4 but decided not to. BTW, The the trans on that car is a 6 speed trans!!!
    right now though, I am really interested in swapping my heads with the eclipses mivec heads. I keep telling my buddy, who works for Mitsu, to see what other parts I would need i.e. pcm, ecu, etc. in order to get the conversion done. but we'll see what happens. Â*will most def. keep everyone posted. :ironchief2:</div> That would be interesting. Does that have a different cam as well? Possibly ECU remapping, hopefully it can be done with our units.
    right now I am still researching everything I can with the help of my buddy to see exactly all of the components that I would need in order to make the swap complete. hopefully once everything is said and done, and I do say hopefully, I will def. keep everyone updated.
    <div class='quotetop'>QUOTE(dragongts787)</div><div class='quotemain'>right now I am still researching everything I can with the help of my buddy to see exactly all of the components that I would need in order to make the swap complete. hopefully once everything is said and done, and I do say hopefully, I will def. keep everyone updated. Â*:D</div> Sounds Good!
    11-05-2003
    1,517
    Update: it looks like greddy is getting in on the act - damn you 9Gs are getting it good:
    2006 GReddy Eclipse GT
    Modifications
    Turbo Kit (prototype) :
    GReddy Prototype T67 with custom SUS manifold and Type T exterior waste gate
    Intercooler Kit (prototype) :
    GReddy Front-mounted Intercooler & piping
    Cat-Back Exhaust (prototype) :
    GReddy EVO2
    Electronics & Displays :
    GRedd Turbo Timer, Gauges, Boost Controller
    Accessories:
    GReddy Shift Knob, Oil Filler Cap, Radiator Cap
    Misc. Engine Parts :
    GReddy Blow-off Valve, Spark Plugs, Oil Catch Can, Radiator Breather Tank, Air Diversion Panel
    Suspension:
    GReddy Front & Rear Strut Tower Bar, (prototype)
    Tein Coil-Over Suspension (prototype)
    Performance Wheels :
    Rays Engineering Volk Racing ME37s (19)
    Performance Tires :
    BF Goodrich KDW 235/35/19
    08-08-2004
    Las Vegas
    2,099
    damn a t67 thats a big ass turbo... there is a guy i know with a rx7 that has a t70 the inlet isso huge i can put my whole fist in it with room to spare
    05-31-2005
    4,735
