Thread: TGC Members Videos...
Page 9 of 9 FirstFirst ... 56789
Showing results 161 to 172 of 172
  1. #161
    08-13-2008
    Waterbury, CT
    3,331
    I have a huge ass 7cm turbo housing from Bullseye, and turbo spool up depends on the size of the turbo housing. If I used 6cm housing the spool up will be around 2500, just like any 14b on 4g64. I remember /Laxinwarrior/Joe's turbo spooling at 3500 and he had the same housing as I have, but with 50 trim instead if 16g.
    forgot you had that housing, but spool shouldnt be that far off for a 16g.. for a 50 trim yes but not a 16g
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
  2. #162
    You don't get it. turbo exhaust housings have numbers 0.42 , 0.48, 0.63, 0.76, 0.98 and many other. The smaller the number is the faster the spool up will be at lower RPMs, the higher the number is - turbo will spool up at higher RPMs. Now with that said, if i put a 14b cartridge on 0.98 housing /although i doubt it will fit/ it will still spool at 8-10k RPMs. And if I put a 70 trim turbo on a 6cm housing it will spool at 2500 RPMs, because the housing is designed to rush more exhaust gases thru the fins and make it spin faster.
    The cold side of the turbo has number too, identical to the exhaust numbers. For the cold side these numbers mean the turbo will be out of its power range and CFMs it supports /runs out of boost/. a 14b which has a number of 0.42 I think and will make that much boost at these RPMs before the map starts going down /it ran out of air/
  3. #163
    08-13-2008
    Waterbury, CT
    3,331
    i do get it, but u never mentioned the exhaust housing number.. i know its larger and i know bow they work.. like i know the 14b on my car will run out of air up top as it can only flow so much before it chokes itself 405 cfm to be exact and i know that the larger housing slows spool, but i didnt think that it would be that great of a difference as it is still a 16g.. it must really struggle to pressurize the exhaust housing as its still a higher compression motor and a relatively small turbo
    2014 Lancer Evo GSR
  4. #164
  5. #165
  6. #166
    Hereis dyno vid of my car...
    http://www.youtube.com/watch?v=qkwMSe13XXI
    this was the 1st run retuning the car from 110 leaded race gas to e85... that run was 414hp (low reading mustnag dyno) after about 10 more runs made 440... 1000cc injectors maxed out. For the hell of it last week dynoed on a dynojet and ended up at 492whp... btw on 110 the car made 523 (dynojet). Thats a super conservative tune only on 21lbs.
  7. #167
    ¿ɹoɟ ʇɐɥʇ op ʇsnɾ noʎ pıp ʞɔnɟ ǝɥʇ ʇɐɥʍ
  8. #168
    just bought a vado hd camera it all right i still havent up dated to the latest software for picture quality yet. but heres a pull i did, punched it gradually not from the start.
    http://www.youtube.com/watch?v=5HGXUtEoVCA
  9. #169
    Quote Originally Posted by Exhaust power View Post
    Where did this video go?
    Eclipse GT 5 spd swapped
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
  10. #170
    This is me and my 2 brothers coming back from east mod 2010
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
  11. #171
    I took it down ill get better videos up soon. just got a mini tripod and a windshield mount for the cam.
  12. #172
    My brothers gst on the way to scranton.
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
