Thread: 5spd swap
Showing results 1 to 20 of 31
    5spd swap
    Hey, im gonna be doing the swap soon, and ive already started part collecting. I got a 2g tranny, and i was wondering if im gonna need the 2g axles also, cuz everyone seems to be unsure
    From 7g to this...
    Shot with DSC-T33 at 2007-07-21
    13.1@109 02 WS6
    count the splines on the tranny
    then get a spline count for 1g manual axles. then you'll know for sure.
    the outer axle however is the same from manual to auto , 2g gst to 7g.
    whats wrong w/ a stock 7g galant manual triany?
    09-23-2002
    Port St. Lucie, FL
    666
    <div class='quotetop'>QUOTE(SuperGALANT)</div><div class='quotemain'>whats wrong w/ a stock 7g galant manual triany?</div>
    nothing is wrong w/ teh 7g manual tranny. Just get the 7g tranny.
    when is we gon be free????
    Bronx NYC (reppin)
    3,489
    <div class='quotetop'>QUOTE(Hodgson316)</div><div class='quotemain'><div class='quotetop'>QUOTE(SuperGALANT)</div><div class='quotemain'>whats wrong w/ a stock 7g galant manual triany?</div>
    nothing is wrong w/ teh 7g manual tranny. Just get the 7g tranny.</div>
    lol, werd homies. I found a spot out in Jerseys with a supply of em. 425
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
    spyder97gs
    Yeah get a 7g. I picked mine up for $250.
    The axles from a 2g eclipse and the same for the 7g. Reused my auto axles in the manual.
    Bronx NYC (reppin)
    3,489
    where the hell did you get it for 250, put a brother on dude.
    spyder97gs
    I used car-parts.com for both my motor and tranny. Got the motor for $230 from Illinois, and the tranny for $250 in Louisville Kentucky. I drove 120 miles to get it though. Thank god for the bosses big diesel
    Kansas City, MO
    1,244
    Well, i finally did it, i dropped a few gears in my AAMCO tranny.... POS...
    Now i have the motivation to put my G under the knife again.
    spyder97gs
    Damn AAMCO trannies! A few of us here have completed the swap and we're always willing to help if needed.
    theblackpearl
    i should be doing the swap by the end of the month if all goes well...
    all i need are my shifter cables, tranny mounts, and clutchline
    i had to get my shit from 3g eclipses, man that sucked, so expensive, just my tranny cost me 700$
    well i just happen to buy the 2g tranny instead of soltero, but now i have to spend like a million dollars to get the 2g axles
    From 7g to this...
    13.1@109 02 WS6
    well be thankful you got a gst tranny, you're going to have alonger 1st gear and your your longer 5th gear will give you a higher top speed than the galant tranny
    but more importantly...
    when cruising in fifth gear on the highway your rpms will be lower than that of a galant 5 speed... so you'll get better gas mileage.
    12-17-2002
    Sherman Oaks, California
    4,304
    <div class='quotetop'>QUOTE(spyder97gs)</div><div class='quotemain'>The axles from a 2g eclipse and the same for the 7g. Reused my auto axles in the manual.</div>
    <div class='quotetop'>QUOTE(reptile)</div><div class='quotemain'> but now i have to spend like a million dollars to get the 2g axles </div>
    huh?
    http://socallifestyle.com/
    1994 Galant GS 5spd
    Bronx NYC (reppin)
    3,489
    I too have been bit by the 5spd bug. getting the tranny on Friday.
    theblackpearl
    and 5spd galants will rule the world!!!
    Bronx NYC (reppin)
    3,489
    all I can say is <span style='font-size:30pt;line-height:100%'>WORD</span>.
    <div class='quotetop'>QUOTE(DOHCSTUNR)</div><div class='quotemain'>well be thankful you got a gst tranny, you're going to have alonger 1st gear and your your longer 5th gear will give you a higher top speed than the galant tranny
    when cruising in fifth gear on the highway your rpms will be lower than that of a galant 5 speed... so you'll get better gas mileage.</div>
    would the first gear effect anything, like my 0-60 times tho?
    From 7g to this...
    13.1@109 02 WS6
    theblackpearl
    <div class='quotetop'>QUOTE(Reptile)</div><div class='quotemain'><div class='quotetop'>QUOTE(DOHCSTUNR)</div><div class='quotemain'>well be thankful you got a gst tranny, you're going to have alonger 1st gear and your your longer 5th gear will give you a higher top speed than the galant tranny
    would the first gear effect anything, like my 0-60 times tho?</div>
    lmao.. first gear is everything on 0-60 times... lol.. the less u shift the less ur time will be
