Thread: Nagging questions
Showing results 1 to 2 of 2
    Nagging questions
    https://www.thegalantcenter.org/viewt...light=cam+gears
    1. with that list......can any be put on with one at a time or what has to be put on all at once
    2. Visionimports.com has the stage 2 kit that i want but where can i get the valve springs upgrade....is it possible to get stage 1 and 2 and would i need anything else after that.....and if i get the stage 1,2 or both and valve springs and tuned at a dyno will i see some hp gain if so can i get a rough estimate of how much.........
    3. Anyone tell me is it cheaper to buy a turbo kit or piece by piece and which will get better results a kit or piece by piece..........
    4. i searched and found that supercharger gets more off the line and turbo gets more power as it goes.........what is the real different between them both....
    1. No, but if you really want to, you can install the FMIC in the front bumper hooked up to nothing...
    2. Depends on what each "stage" comes with. MOst likely not, these arent Dodge Neons.
    3. Depends man. Of course you could do it cheaper piecing it together, but you would be buying used parts on a budget. And the results would depend on what parts you buy and how you tune it.
    4. https://www.thegalantcenter.org/viewt...pic.php?t=22187
    Those are very very broad questions that have been beaten to death with a 10ft stick on TGC over the years.
