are you sitting on some rediculously sized wheels?Originally Posted by bizo2
are you sure your springs were installed properly?
what brand did you use?
i got my ride lowered and now the rear wheels hit the wheel well.
how can i fix the problem?
do i did to get stiffer shocks or stiffer springs?
2001 Galant GTZ
i have 18x8 hp evo wheels and h&r springs
2001 Galant GTZ
get your fenders rolled or even cut.
I had the same problem with my 19X8 and the tein springs.You have to roll the rear fenders or use a rubber mallet and hammer it back.Heat the paint with a hair dryer so it doesn't crack when you roll them back.Good luck.maximus
if youre gonna roll your fenders, heating helps. but also, use a razor blade and cut along the undercoating just inside of the rear fender, that way when you bend the fender edge back, the stock paint isnt pulled along with the fender.
wow, i have had 2 different sets of 20' rims/tires and 1 set of 19' rims/tires and all of them were 8.5' wide and never had that problem before. i even had airbags at one time and never had any problems. i now have tein springs with agx struts lowered with 20's and no rubbing at all.
sound like a lot of work
thanks you'll
2001 Galant GTZ
