Removal of Interior Pieces
Hello All,
I have tried numerous searches and found nothing so I guess I'll ask now.
I remember somebody giving step-by-step instructions on how to remove interior pieces for paiting (ie..vents,dome light housing)
If anyone has that information I would greatly apprectiate if you share it with me.
Thanks.
its pretty easy actually. what i did was take a very small flat head screwdriver, and pressed it to the side and then in of the pieces i was working with. the vents when you take them out have to be careful, because the clips on the inside will want to snag in certain spots. other than that its very easy. if you want to do the door panels, that will require you to remove the doors of course. when you do, just unscrew the screw that hold the pieces in place, and take them out. if you need more help, just ask
Shylynn did post a tutorial when this board was fisrt up and running trying doing a search on her name to see if you can find the post
